Trans cooler
Old Jun 17, 2007 | 12:35 PM
Dobbie1950's Avatar
Dobbie1950
Junior Member
Default Trans cooler
[8D]I'm about to install atransmission cooler on my 05 dakota and would like to know witch line to cut into. I know its the return but is it the right or the left.
Old Jun 17, 2007 | 03:33 PM
DakotaStone's Avatar
DakotaStone
Default RE: Trans cooler
I only know of one guy whose ever added a trans cooler on his 05, but he hasn't been on this site forever. Wish I could help you.
Old Jun 17, 2007 | 04:31 PM
Dak_in_Black's Avatar
Dak_in_Black
ORIGINAL: Dobbie1950
You are in luck!! I just switched out all the tranny fluid(including the torque converter) to amsoil...
I am gonna take a guess that you already know where the hoses are located. The one on the passenger side is the output line from the convertor to the radiator. The hose on the driver's side is the return line from the radiator back to the convertor.
Let us know how it goes (pics would be nice), I am considering the same soon myself...
Old Jun 17, 2007 | 05:42 PM
Cuban11182's Avatar
Cuban11182
Yup me too. Hey Dak in black besides the pita trans how did the rest of the changes go. Do you have the posi end? Im gonna be going overseas and before I do Im thinking of replacing with all synthetic.
Old Jun 17, 2007 | 10:07 PM
Dak_in_Black
ORIGINAL: Cuban11182
Well, we already know about the oil and the cross member rught under the drain hole.
The rear diff wasabout the easiest, used a rubber mallet to knock thecoverloose.
I guess you *could* take the tranny pan off without removing the cross member, but I was just so pissed that it was in the way.
The front diff is a PITA, I think Frenchy had about as much fun as I did. There is just not a whole lot of room there to work.
So far everything seems to be running smoother. The tranny shifts much smoother now, and it seems to roll easier with the diff fluids replaced. But that is just 'seat of the pants', I am tracking mileage to see if there is any improvement...
Old Jun 17, 2007 | 10:47 PM
Dobbie1950's Avatar
Dobbie1950
Junior Member
Dak_in_black, Thanks for the information, I really wasn't looking foward to breaking those connections. I went through 77 pages on this forum the other day and found one guy who installed a cooler on his Dak. He had pictures from the front but none where he connected to the lines. Thanks again.
Old Jun 18, 2007 | 03:04 AM
Frenchy's Avatar
Frenchy
the front differential can kiss my butt...
Sucked sooooooooooooooooooooooooooooooooooooooooooooooooo ooooooooooooo much!!!!
Old Jun 18, 2007 | 03:16 AM
Frenchy's Avatar
Frenchy
Also, how much is a tranny cooler, and who makes a good one, or whatever?
I want this truck to last me forever, so I'm trying to make it so it will.
And the damn Getrag tranny will cost about 3500 dollars if it ever goes bad....
So.... I'd rather not have to fix that for a LONG time, so I'd like to keep the temps cool in there.
Old Jun 18, 2007 | 11:36 AM
rick4dak's Avatar
rick4dak
All of you are familiar with the tranny coolers that mount on the radiator but there is another type that is typically used on street rods. They are tubular, finned aluminum coolers that mount under the vehicle and eliminate the need for radiator-mounted coolers. If you are interested, I'll locate a web site and post it.
Old Jun 18, 2007 | 01:14 PM
Altair's Avatar
Altair
Dak attack!
The tow package already has a transmission cooler from the factory right?
