hauling drywall
my drawing explains it all...disreguard my tonneau
brown = sheet of plywood
white = sheets of drywall
blue = tie downs
if the pic doesnt work. click the link
http://s59.photobucket.com/albums/g2...urrent=bad.jpg
you might want to put a blanket between the wood/drywall and your bed and bed walls...just an idea
blue = tie downs
All you need to do it cut two lengths of 2x4 to fit in the flat spots on your bed sides. Put the 2x4s across the bed and stack the drywall on top of them. Ratchet-strap the drywall sheets down front and rear. Obviously you'll need to leave the tailgate open.
lol im at work. if i was at home i would have used cs2 (photoshop) and it may have been better...im no pro, but i was gettin better for a while...havent really worked at it since i made the pics below
here are links to some things i made from scratch
http://s59.photobucket.com/albums/g2...nt=saturn1.jpg
http://s59.photobucket.com/albums/g2...urrent=sky.jpg
http://s59.photobucket.com/albums/g2...ent=storm1.jpg
http://s59.photobucket.com/albums/g2...rrent=gta1.jpg
and i also made some pretty kick *** decals, ask the guys
ORIGINAL: rick4dak
Our beds are more than 4 feet wide above the wheelwells. That's why the 2x4s are needed.
Trending Topics
Originally Posted by ALLPAR
CARGO BOX DIMENSIONS
Club Cab
Quad Cab
Nominal Box Length, ft.:
6.5
5.25
Length at Floor, Tailgate Closed:
78.8 (2001.5)
64.9 (1648.1)
Length at Floor, Tailgate Open:
100.3 (2546.6)
86.3 (2193.1)
Interior Width, Maximum:
59.6 (1514.0)
Distance Between Wheelhouses:
45.2 (1146.9)
THE 2 X4 'S MENTION PREVIOUSLY WILL RAISE THE DRYWALL ABOVE THE WHEELWELLS SO THE SHEETS WILL FIT FLAT.
Tailgate Opening Width:
53.3 (1355.0)
Depth:
17.6 (446.9)
Volume, cu. ft (cu. m):
46.6 (1.32)
40.25 (1.14)
Club Cab
Quad Cab
6.5
5.25
78.8 (2001.5)
64.9 (1648.1)
100.3 (2546.6)
86.3 (2193.1)
59.6 (1514.0)
45.2 (1146.9)
53.3 (1355.0)
Depth:
17.6 (446.9)
46.6 (1.32)
40.25 (1.14)
Honestly anything that raises it up above the wheel wells will work, a standard twin mattress is about the same height as the wells and fits inbetween them. Probably don't want to use your bed to put drywall on though
