Tow bar brackets
Old Jul 1, 2007 | 07:24 PM
05 Dakota towing's Avatar
05 Dakota towing
Default Tow bar brackets
I'm trying to bolt brackets to the frame underside on the front of my 05 Dakota. I can't loosen the 19mm bolts that goes thru the frame vertically up thru 2 rubbergrommets/pads. The bolts hold the front of the body on, next to the radiator mounts. I'm trying to mount a Roadmaster towbar bracket kitso I can tow this behind my moterhome. Does anyone have any ideas? Thanks.
Old Jul 1, 2007 | 08:19 PM
superdak05's Avatar
superdak05
Default RE: Tow bar brackets
soak the bolts with pb blaster and let it sit. what happens is all the road grime gets bonded onto the threads and it needs a little help to get free.
