Electric Fan Setup
Old Jul 8, 2007 | 05:10 PM
Cuban11182's Avatar
Cuban11182
Default RE: Electric Fan Setup
So pro 4x4 should i put some sort of thermostativ valve on the keyed 12v accessory so that it interupts the power supply to the relay until the proper temp is reached? Can you do up a quick electrical schematic on how you wired yours up. Thanks
Old Jul 8, 2007 | 05:21 PM
pro4x4's Avatar
pro4x4
I'll enclose the diagram I used but I have a flex-a-lite fan so its going to be different. My fan has a control box and a temperature probe that you push in between the radiator fins and it has a **** on it so you can set it to turn on at a certain temperature.
[IMG]local://upfiles/60735/589B6FD4C96D431491F5D8F60CD47BFE.jpg[/IMG]
Old Jul 9, 2007 | 12:47 PM
DakotaStone's Avatar
DakotaStone
Could you post that in the mods talk? This way we can look it up at anytime.
Thanks.
Old Jul 9, 2007 | 02:49 PM
Cuban11182's Avatar
Cuban11182
This is a one relay schematic i made. Both of them will work. I have also included how the realy works because up until yesterday I didnt know how it did. http://www.flickr .com/photos/70511334@N00/762328509/ near the top click on the magnifing glass that says all size
Old Jul 10, 2007 | 04:31 PM
skikir's Avatar
skikir
What are you using for thermostats? I put a electric fan in my Triumph TR6 and it really worked well and made a big difference in power and milage. It was a cheap system using a thermostat stuck in the cooling fins of the radiator. Butif I were to take this truck out in the wild and climing a mountain where I really would need it I'd want a two speedfan or two fansfor extra cooling. I'd like the thermostats actually in contact with the coolant for more accurate readings.
Old Jul 10, 2007 | 04:37 PM
Cuban11182's Avatar
Cuban11182
well at auto zone the sell a kit with a thermobulb that you slip into the bottom radiator hose and then clamp it down. They are adjustable from 150-210 i believe. I just dont like the idea of clamping it down. If anyone knows of another type of setup please let me know. Thanks
