First Oil Change
Old Jul 22, 2007 | 10:44 PM
slaterracing's Avatar
slaterracing
Default First Oil Change
Why the hell does the factory have to put the oil filter on so F'n tight. I use filter pliers to remove the filters on all the cars i do. This time it took everthing that i had to get it off. I even ended up squeezing the pliars so hard i put holes in the filter. But i finally got it off. That is the reason the dealer will never do a oil change for me. They do the same thing the factory does.
Old Jul 22, 2007 | 10:46 PM
Frenchy's Avatar
Frenchy
Default RE: First Oil Change
Hahaha, how'd you like that dang crossbar being RIGHT in the way, as well?
Old Jul 22, 2007 | 10:48 PM
slaterracing
ya that was fun. between that and all the coolant lines all over the place. i think i was under the truck longer wiping it down when i was done.
Old Jul 22, 2007 | 11:16 PM
Jr. Mechanic's Avatar
Jr. Mechanic
I had the same problem with my 3.7, they put it on so tight and you cant get anything on there, I ended up using channel locks after about two hours and a completely destoyed filter.
Old Jul 22, 2007 | 11:37 PM
mb18's Avatar
mb18
I punched a hole in mine with a flat tip screwdriver, drained it, and then used the screwdriver as leverage to twist it off. The oil pan caught most of the mess and the filter was off in a few minutes.
Old Jul 23, 2007 | 12:53 AM
Jr. Mechanic
I punched a hole in mine with a good sized screwdriver too but all it did was cut the filter in half as I turned it[&:]
Old Jul 23, 2007 | 09:28 AM
curtiplas's Avatar
curtiplas
Eh I didn't have a problem at all I mean it was on tight... but I used a filter wrench and with a lil' pressure in the right spots came off no prob... :-P... you should put synthetic in ur truck if you didn't already...
Old Jul 23, 2007 | 10:03 AM
slaterracing
Ya i am using Mobil 1 in it. Kinda nice because it uses the sameweight as my 07 Fusion so buying it in bulk will be nice.Internet is nice for stuff like that.
Old Jul 23, 2007 | 05:59 PM
pro4x4's Avatar
pro4x4
Yea my filter was on tight too. I completely crushed the filter trying to get it off. These auto companies make thing so difficult for us do it yourselfers.
