Spark Plugs update...
Old Aug 16, 2007 | 01:05 AM
  #41
Frenchy's Avatar
Frenchy
Default RE: Spark Plugs update...
Wait,, what am I doing!?!?!??!
Old Aug 16, 2007 | 01:16 AM
  #42
dodgerules86's Avatar
dodgerules86
Frenchy, their volunteering you to do the following:
ORIGINAL: rick4dak
The perfect heat range depends on your specific driving style as well as quality of gasoline.
Hotter plugs will resist fouling because deposits tent to burn off better.
A higher voltage spark allows wider gap. Modern electronic ingition is much more tolerant of wider gaps. .035 or .040 will probablt not make a noticable difference. In theory, a wider gap will allow better fuel ignition but it would be surprising if anyone could detect a difference of .005" in either performance of mileage.
I think somebody on this thread should do the research...
Old Aug 16, 2007 | 01:39 AM
  #43
4x4QC06V8DKTA's Avatar
4x4QC06V8DKTA
since you are our grand noble leader sire!
Old Aug 16, 2007 | 02:45 AM
  #44
superdak05's Avatar
superdak05
i stuck with the .040 gap with the autolite 3923. but even interesting about the 3922. i night have to try that out. but for now i am real happy with the plugs.
Old Aug 16, 2007 | 07:18 AM
  #45
BACKnBLACK's Avatar
BACKnBLACK
thanks for the feedback, superdak 05. you the only one that answered my question...at least about the gapping...but,
I didn't ask what our trucks didn't have, I asked what else you had to replace guys.
Old Aug 16, 2007 | 07:56 AM
  #46
luvmydak's Avatar
luvmydak
Did mine couple of weeks ago. Just disconnect the connector and the hold down nut then wiggle the coil assembly a little and lift out . I strongly suggest if you don't have one already get a magnetic type deep socket or one with the rubber internal insert to hold the plug. This is a deep opening. You will not be able to grip the plug with your fingers.
Old Aug 16, 2007 | 09:18 AM
  #47
Altair's Avatar
Altair
Dak attack!
ORIGINAL: BACKnBLACK
I think the wires are part of the coil pack, if that's the case you can't change the wires without changing the coils. As for the gap .035 is for the V6 w/ autolite 3923's. For the V8 you want .040
Old Aug 16, 2007 | 11:58 AM
  #48
4x4QC06V8DKTA
yeahp...can't replace just wires...cause its a coil to plug set up!
Old Aug 16, 2007 | 12:28 PM
  #49
luvmydak's Avatar
luvmydak
I also have the shop manual on disc and unless the wires which are connected to anti-knock sensors are damaged you do not have to replace them, unlike the previous spark plug cables(pre Gen3).
Old Aug 19, 2007 | 09:34 PM
  #50
curtiplas's Avatar
curtiplas
+1 on the magnetic or rubber inserted socket for spark plugs... cuz that is one deep hole... hahaha... and yeah I went with .35 on my v6... if you have a v8... IDK... so yeah...
