Spark Plugs update...
Old Dec 14, 2011 | 07:56 AM
  #51
Tango8's Avatar
Tango8
WHAT IS CORRECT GAP AN PLUG FOR A 2010 4.7,4x4 Dakota
Old Dec 14, 2011 | 08:10 AM
  #52
FrenicX's Avatar
FrenicX
Originally Posted by Altair
I think the wires are part of the coil pack, if that's the case you can't change the wires without changing the coils. As for the gap .035 is for the V6 w/ autolite 3923's. For the V8 you want .040
What he said
Old Dec 15, 2011 | 10:22 PM
  #53
JimBio's Avatar
JimBio
Upper .039"
Lower .051"
According to owners manual
I used Bosch Super Plus 7962 on the uppers and Bosch Platinum +2 4308 on the lower. They have been in for a year or so and it runs like butter.
Old Feb 11, 2013 | 07:51 PM
  #54
Anthony Grego's Avatar
Anthony Grego
jimbio... u have 16 spark plugs on the 2010s?? im confused
Old Feb 12, 2013 | 11:56 PM
  #55
jasonw's Avatar
jasonw
Site Moderator
In the 2008 model year, Dodge upgraded the 4.7L V8.
For 2005-2007 model years, the 4.7L V8 made 230 HP and 290 lb-ft of torque. If you managed to find the rare 4.7L HO, or High Output, you got 250 HP and 300 lb-ft of torque, albeit at the higher cost of premium fuel all the time.
In 2008, they made it a lot more like the HEMI. Two spark plugs per cylinder, drive by wire throttle (fully electronic, no throttle cable), etc. 302 HP and 329 lb-ft of torque, with regular fuel and slightly better fuel economy. Kept it that way through the end of the Dakota's run in 2011.
The upper bank on top is meant to be changed like regular spark plugs, coppers. The lower bank is meant to be changed half as often, and are platinums.
Old Mar 7, 2013 | 03:37 PM
  #56
Anthony Grego
so im all in for the 3923s, especially since my engine is idling like michael J Fox off his meds (going to hell for that but it makes the point) but which 3923 did you guys go with, the copper, platium, double platium or the irridiums?
whats the advantage of one over the other other than higher duability of the plug?
Old Apr 30, 2013 | 07:20 PM
  #57
Topcubmartin's Avatar
Topcubmartin
So I did the autolite plugs.... My truck is running no smoother, if not worse than before
Old May 2, 2013 | 10:28 PM
  #58
Anthony Grego
just did the autolite 3923 swap in my 05 4.7L and she is running beautifully, that pep is back in her step and the shaking at idle is pretty much gone, as I was pulling the old plugs I measured the gaps, holy hell they were bad and the plugs were almost eaten away at the tips all the way into the ceramic.
Old Sep 1, 2013 | 07:22 PM
  #59
Adams95ta's Avatar
Adams95ta
I used this writeup http://diysrc.com/change-the-spark-p...ubishi-raider/
Old Sep 2, 2013 | 11:24 AM
  #60
bill52's Avatar
bill52
any one every try the " E-3's " on the 05 4.7???
