stowing my dak... advice?
Old Jul 31, 2007 | 11:48 PM
flyboy1304's Avatar
flyboy1304
Default stowing my dak... advice?
so i'm deploying soon, my truck is going to be stored in a storage unit... for atleast 6-8 months... and will not be driven at all....what should i do in preperation to store it.
obviously drive it till the gas tank is pretty much empty, dis-connect the battery, empty the oil?
not really too sure what to do... never stored a vehicle before...
Old Aug 1, 2007 | 12:02 AM
Altair's Avatar
Altair
Dak attack!
Default RE: stowing my dak... advice?
Well when we store our snomobiles for the summer we usually put some stuff in the gas tank to keep the gas from gettin all crappy, forget what it's called though. You could even try googling for "storing a vehicle" or something similar. This site came up for me, seems pretty helpful: http://www.openroad.com.au/motoring_...ingyourcar.asp
Old Aug 1, 2007 | 12:07 AM
Frenchy's Avatar
Frenchy
I wouldn't empty the tank....
I think bad things could happen from that... like moisture accumulating in the tank....
Old Aug 1, 2007 | 12:16 AM
turbot_bird's Avatar
turbot_bird
fill the tank to the top, add sta-bil to the gas, put it on blocks to save the tires, ill come up with more tomarrow when Im not so tired
Old Aug 1, 2007 | 12:26 AM
dodgerules86's Avatar
dodgerules86
ORIGINAL: Altair
Sta-bil comes to mind.
Before you leave, give it lots of love, and remind it that you won't forget about it.
When I left, I had a friend start it up every couple weeks. He also needed to fill up one of the tires due to a slow leak (whichI still need to get fixed ). You know, run it for like 10 minutes, turn the A/C on, pump the brakes, put the transmission in neutral (reason being, Chrysler automatic transmissions evidently don't pump fluid in park, I'd just like the idea of having the fluid moving every couple weeks), just give it a good look over.
If you can store it at a place with some space, have that friend move the truck to get fluid circulated in the axle(s) and t-case (if 4WD).
Of course, thats just my suggestions.
Hope your deployment goes well and you come home safely.
Old Aug 1, 2007 | 01:13 AM
superdak05's Avatar
superdak05
best advice would be to give the keys to someone you trust and let them take it around the parking lot to keep everything well maintained. or find a place that would do it. butthat will be expensive
Old Aug 1, 2007 | 07:13 AM
Kerrbear219's Avatar
Kerrbear219
Same as my hubby does for his bike during the winter.....FILL the tank (DO NOT empty it, above advice about moisture is so true)....Sta-bil added to the gas.
Good luck and god bless.....come home safe!!!
Old Aug 1, 2007 | 07:14 AM
turbot_bird
ORIGINAL: turbot_bird
disconect the battery. ok, ill remember more latter. thats how we do all the cars we have
Old Aug 1, 2007 | 06:21 PM
flyboy1304's Avatar
flyboy1304
cool, so stabilland full tank... everybody i know is deploying with me there all on my fire team... so theres not anyone else i can leave my truck with...
