led problem................
Old Sep 7, 2007 | 05:57 PM
BAdassR/T's Avatar
BAdassR/T
Default led problem................
so i ordered 24 led light bulbs for the brake lights and i installed them. I come to find out when i went to use my turn signal they wouldnt work, lol dont understand why, anyone have a problem like this before, anyone have any answers to why this would happen?
Old Sep 7, 2007 | 06:21 PM
coondog05's Avatar
coondog05
Default RE: led problem................
need resistors!!!! look in old posts theres tons of info!!
Old Sep 7, 2007 | 11:26 PM
jimboscomp's Avatar
jimboscomp
yes, without the resistors the lights will not work at all. I tried to go without them too when I first made the switch, but I had to get them :-/
Old Sep 8, 2007 | 11:52 AM
BAdassR/T's Avatar
BAdassR/T
alright thanks i ordered them... guess i gotta take those out for now....................
Old Sep 8, 2007 | 11:14 PM
Deer Hunter's Avatar
Deer Hunter
Just a heads up. When I got my resistors, my lights still didn't work. I found that those little splicers they give you wouldn't cut through the insulation. So, I ended up snipping, stripping and butt connecting.
Old Sep 9, 2007 | 01:00 AM
jimboscomp's Avatar
jimboscomp
oh yeah that's a good point! I did the same...those splicers they come with suck. Also, MAKE SURE you get the right wire. Uhm....just check with a multimeter which circuit flashes on and off when you turn on your flashers to see which wire you need to splice into.
Old Sep 9, 2007 | 07:52 AM
Dak_in_Black's Avatar
Dak_in_Black
ORIGINAL: Deer Hunter
Yeah, the splicers are 'ok' not the greatest. Had the same thing when I installed the power tailgate lock, I just cut away a little of the insulation and used the splicers.
Old Sep 9, 2007 | 09:50 AM
BAdassR/T's Avatar
BAdassR/T
Thanks for the info prob save me alot of time!
Old Sep 10, 2007 | 09:00 AM
luvmydak's Avatar
luvmydak
Had the same problem myself with a tail light led install. Finally gave up and sent the kit back for a credit. So then, a direct spliceshould work?
Old Sep 11, 2007 | 07:35 PM
Deer Hunter
Yes, a direct splice works great. The resistors get very hot, but can be mounted to the bed via the little wing with the two holes. When you pull out the taillight, look straight in and you'll see it. Just don't make your splice too close to the bulb. That way you'll have enough wire to work with next time you have to pull the taillight assembly out to change a bulb or whatever.
