ride height
Old Sep 13, 2007 | 04:33 PM
WIZARD's Avatar
WIZARD
Default ride height
i am going to put the air-lift bags on this weekend but i need to set the truck to factory ride height (distance from bottom of fender lip to center of rear axle) but i have a cap on and do not want to remove as i am by self so can some one with an x-cab 4x4 with nothing in back measure theres for me more then one would be ok as that way does not have to be exact to factory specs
thanks in advance for anyones help
Old Sep 13, 2007 | 04:54 PM
Cuban11182's Avatar
Cuban11182
Default RE: ride height
did you lower it?
Old Sep 13, 2007 | 05:47 PM
WIZARD's Avatar
WIZARD
no but the cap alone i am told byjeraco is 500lbs
Old Sep 13, 2007 | 06:19 PM
Cuban11182's Avatar
Cuban11182
[&:][&:] WOW thats alot!!Lift the rear as high as you want. They are leafs in the back so just raise it till it looks good....and I don't mean the ole angry stinkbug look
Old Sep 13, 2007 | 07:20 PM
Dak_in_Black's Avatar
Dak_in_Black
ORIGINAL: WIZARD
I find that very hard to believe... I have an A.R.E and it is between 150 and 180 lbs.
The largest cap they have (full size truck, full length bed) is only 200 lbs...
Old Sep 13, 2007 | 07:27 PM
WIZARD's Avatar
WIZARD
dont care about after. i need factory ride height for inital intall. truck has to be at factory ride height to properlly place brackets at angle and distance with installation tool. no more no less what i did to or am going to do to truck means nothing
Old Sep 13, 2007 | 07:39 PM
Cuban11182's Avatar
Cuban11182
Well I would go out and hook you up with some numbers but my truck is a quad....sorry
But yea that cap seems extremely heavy.....
Old Sep 14, 2007 | 02:17 PM
mb18's Avatar
mb18
Is your cap one of those all commercial caps with the ladder racks, tool compartments and such? I could see one of those being more than 200 lbs., especially loaded. If not, I can't imagine it's more than 150-200 lbs.
Old Sep 14, 2007 | 08:35 PM
Nocturnal's Avatar
Nocturnal
Wizard - you don't need to be at factory height to install your bags. Once your bags are on - you will need to keep at least 5psi in each one at all times. So I would install them at your current ride height and then when you put 5psi in them, you will be close to factory height when you are done. If you raise it first and then install them and add 5psi - you will sit a little higher than stock and have the front end low. It will feel weird driving it. I wish I knew this when I did mine. Now I need to add a level kit to get the truck back to normal.
Also, from personal experience - install the drivers side first. I found that when I did mine - I did the passenger first and when I went to do the driver's side I couldn't line it up in the exact same place because the brake cables were in the way. I had to undo the break cables and move the bag slightly to mount it. This forced me to run separate air lines for each bag and adjust the pressure to keep the truck level from side to side. When the truck is empty, I have 5psi in the passenger side and 8psi in the drivers. When I load it down - I have to offset them a full 5 psi to level the truck. I will eventually fix this by moving the passenger side bag so they are the same, but since I don't want to drill another set of holes in the frame - this will require me to weld them up instead of bolting them. Welding isn't a big deal, I own a welder and I'm competent with it, it's just time consuming and I have a lot of other projects going right now.
I hope all of this helps - sorry for such a long post.
Old Sep 15, 2007 | 03:09 AM
Altair's Avatar
Altair
Dak attack!
If you still need the measurements let me know, I have an 05 club cab 4x4 with the front leveling kit but that shouldn't affect the back height. I can't get anything till tomorrow when I get my truck back from my friend's place tho, too drunk to drive it home tonight.
