2005 4.7L Magnum w/22k miles....dies....why??
Old Oct 16, 2007 | 01:23 PM
87LtdT's Avatar
87LtdT
Default 2005 4.7L Magnum w/22k miles....dies....why??
Hasn't happened to me as I seldom drive it, but wife says on 4 seperate occasions now the truck has died while waiting at a light or stop sign??
Any ideas??
Thanks, Bob
Old Oct 16, 2007 | 01:24 PM
mb18's Avatar
mb18
Default RE: 2005 4.7L Magnum w/22k miles....dies....why??
Sounds like this same issue:
https://dodgeforum.com/m_984951/tm.htm
Old Oct 16, 2007 | 01:26 PM
mb18's Avatar
mb18
beat ya to it!
Old Oct 16, 2007 | 04:04 PM
pack154's Avatar
pack154
I had the same the happening to my 05 with the same engine you have. I actually did a post about two weeks ago so its somewhere on here. I'm sure the other guys have given you the info already. They have been very helpful on here.
If your "check engine" light is not going off when this happens then its more than likely the throttle body needs to be cleaned out. I brought my truck in two weeks ago and they changed the plugs and cleaned the throttle body and I haven't had the problem since. The only bad part about it was that the warranty didn't cover it.
Old Oct 18, 2007 | 06:29 PM
87LtdT's Avatar
87LtdT
Thanks guys for the rapid and helpful responses. I drove the truck yesterday and it died on me too...not quite stopped rolling yet at a red light and it just quit running. No lights on the dash. A friend has an OBD2 tool and found no codes ever recorded.
I'm gonna clean the throttle body first and only.
If still dieing will change plugs...if that don't do it I'll take to dealer.
A question: If no codes found, will the dealer charge me to reflash the computer?? I am still well within the warranty window.
Thanks again, Bob
Old Nov 21, 2007 | 08:10 AM
87LtdT's Avatar
87LtdT
An update: I used carb cleaner to spray the throttle body and the odd shaped slot below and to the right of it ...nothing scientific...just used about 1/4 can of cleaner while running and shut off. That is all that I've done.
It has not died once in the month since.
Bob
Old Nov 21, 2007 | 12:47 PM
superdak05's Avatar
superdak05
i just turned 47000 miles on my 05 and never had an issue with this. your throttle positioning sensor might need a simple adjustment. it is two screws that bolt it onto the tb. you may need to loosen them up and move it a little
