What size speakers?!
Old Oct 26, 2007 | 06:43 PM
AdidasCJ's Avatar
AdidasCJ
Default What size speakers?!
Does anyone know what size speakers are in our front and rears? I have the ClubCab... I know someone knows and i would be thankful for the info....
Are they 6.5 or 6 3/4 or 6....
Cruchfeild is sayin 6 3/4
Old Oct 26, 2007 | 06:52 PM
Nocturnal's Avatar
Nocturnal
Default RE: What size speakers?!
I think ourdoors and rear doors are and odd size of 6.75. But 6.5s will fit without any touble. My advice would be to look up the truck on a site like
www.crutchfield.com
That site will tell you the size and if there are any things that need to be considered in your decision.
Old Oct 26, 2007 | 06:55 PM
Nocturnal's Avatar
Nocturnal
Just saw your last post. They are 6 3/4 but, 6 1/2 will work. I just chaged mine last week.
You can also mount 6 1/2s in the rear doors of a club cab. If you take off the plastic you will see that there is a speaker hole stamped in the metal in the upper rear part of the door. I used this location for my rears and unhooked the facory rears since they were being muffled by the sub enclosure anyway.
Old Oct 26, 2007 | 07:07 PM
AdidasCJ's Avatar
AdidasCJ
ORIGINAL: Nocturnal
I know what stamp you are talking about.... but.... problem is.... I already used that space on my rear swinging doors.....
And i like this stuff there better then a speaker
Old Oct 26, 2007 | 07:36 PM
Altair's Avatar
Altair
Dak attack!
I'd go with 6.5", this is how I installed mine: https://dodgeforum.com/m_825033/tm.htm
I really need to add the rears to that and ask a mod to put it in the DIY section, almost forgot about it...
Old Oct 26, 2007 | 07:48 PM
teva_feet's Avatar
teva_feet
most 6 1/2 and 6 3/4 speakers will work with the factory mounts (Altair's DIY write up looks great) but keep in mind that some component speakers have a tweeter that sticks out a little far from the speaker face and will cause problems with the embedded grill on the door.....I've seen one mod to get around that by using a dremel tool to cut out the door grill and using whats provided by speaker mfg, thats what I'm thinking about doing with a couple pair of infinity kappas I have kicking around
Old Oct 26, 2007 | 09:03 PM
superdak05's Avatar
superdak05
i dont use my cc back seats so i went with the boxed 6 x 9 , much better sound then the ones in the rear compartment.
