Q for those w/ 4x4 & the TM level kit.. (pix inside)
RE: Q for those w/ 4x4 & the TM level kit.. (pix inside)
Damn Dirty Ape, I dont believe that the TRX4 is 1 inch higher in the front by any means, even though its been stated here and there. Right now, with the kit installed, what do you measure from dead center of your wheel (or axle) to the top middle of the wheel well? Nearly all our trucks sit about 20" and 21.5" with the kit installed. If your measuring above that, they I guess there really is a difference.
ORIGINAL: MonkeyWrench4000
Mine measured 19 1/4-1/2" from center cap to top middle of wheel arch. Rears are 21.50" That is without a kit on the front.
herkguy : I'll check tonight by doing that test. I'm not so much worried about the travel limits, but the fact that the shaft is no longer straight and each joint is going to pivot slightly in a couple of directions each time the wheel turns a revolution.
I know that they aren't perfectly straight by any means, but at minimum the cv joint will most likely go 'out' sooner than normal based on the increased shaft angle, correct?
all I know is:
.ÊŽ1ÇʇÉ1 ʞɔnɹʇ ʎɯ ɹÇpun Çɯıʇ ɥɔnɯ ooʇ ʇuÇds ÇÊŒ,ı
all I know is:
I have over 10 000 kms on the kit so far and lots of wooden road but some real off roading in the last few weeks and holding it's ground pretty good... But as I said before there will be some stuff to be check with my mecanic to make sure it is safe but... I was awared of the potential risk and will remove as soon as the first problem arrise... Warranty will still cover it the garage cannot proof is is cause by the level kit...
ORIGINAL: moosehunter
