electric fAN
Old Dec 12, 2007 | 11:34 AM
  #21
curtiplas's Avatar
curtiplas
Default RE: electric fAN
Superdak what are is the CFM on that fan??
Old Dec 12, 2007 | 11:16 PM
  #22
studlyblueiz's Avatar
studlyblueiz
for those that are interested in the Taurus fan just look for a mid 90s 3.8L v6 ford. it'll be a single "s" blade fan with a 3 prong plug. I have one I plan to put in mine I just haven't bought a controller I wanna test out.
Old Dec 14, 2007 | 10:28 PM
  #23
kingsaffey's Avatar
kingsaffey
what temp did u set the thermostat at to turn it on
Old Dec 15, 2007 | 12:03 AM
  #24
studlyblueiz
I don't know what anyone else put theirs on but I figured I'd have mine come on at 180. With the controller (I already know I'll see it xmas) I plan to use should cut off when it gets lower than that and if it gets to whatever I set the second temp to it'll change to full 100% power.
Old Dec 15, 2007 | 10:47 AM
  #25
kingsaffey's Avatar
kingsaffey
so basically this prodct come with a new tstat thats adjustable or is it like a switch
Old Dec 15, 2007 | 02:55 PM
  #26
pro4x4's Avatar
pro4x4
The flex-a-lite fan comes with a control box with a **** to adjust it. When the temperature gauge in the instrument panel gets to the half way mark turn the **** on the controler until the fan comes on. Then whenever the temerature hits the half mark on the gauge the fan will come on.
Old Dec 15, 2007 | 03:17 PM
  #27
kingsaffey's Avatar
kingsaffey
o ok i see.so there no actual specific temp just look when the gauge is half way
Old Dec 16, 2007 | 05:55 PM
  #28
pro4x4's Avatar
pro4x4
Right the half way mark is about 200 degrees so with a 195 degree thermostat when the temp hits that mark the fan will turn on and drop the temp back to 195 or slightly below. I actually have mine set to turn on when the temp gauge is just a hair below the half way mark. You should set the fan to come on when the temp goes 5 degrees above the normal operating temp which is 195. Now if you have a 180 degree thermostat installed then your normal operating temp will be 180 so you want to set the fan to come on at 185.
Old Dec 16, 2007 | 06:18 PM
  #29
kingsaffey's Avatar
kingsaffey
oksounds easy enough, thanks alot
Old Dec 19, 2007 | 11:29 AM
  #30
RMUDBUGS's Avatar
RMUDBUGS
Someone needs to post a "how to" on the Black Magic kit. With lots of picks.
