underdrive pulley system
Old Dec 11, 2007 | 11:34 PM
Destructicon's Avatar
Destructicon
Default RE: underdrive pulley system
nice so your clocking like about 23.8 to 24.4 mpg? (oh yeah that was done via brain power, Hahahaa) What temp and Oct level are you running? Just wondering cuz I was experimenting with my wife's 06 Corolla a few weeks back with mpg ratings when in CA with lower air temps vs. AZ and higher elevation and thinner air. I know the concept and formula works out, but with a larger block and heavier truck, does mathmatics and physics correlate??
Old Dec 11, 2007 | 11:37 PM
kingsaffey's Avatar
kingsaffey
i put 93 oct in my dak i get well over 20mpg. im glad that in texas 93 oct is under 3 dollars. back in ny i was paying alomost four dollars at one point
Old Dec 11, 2007 | 11:54 PM
Frenchy's Avatar
Frenchy
I use 93 octane only, and it was around 90 degrees.
Old Dec 12, 2007 | 12:03 AM
ChadJK's Avatar
ChadJK
I'll be the dumb one...
What exactly is an underdrive pulley system? How does it differ from the factory original? What exactly does it accomplish and how does it accomplish it?
Old Dec 12, 2007 | 12:30 AM
Racinartist's Avatar
Racinartist
ORIGINAL: Destructicon
Its worth it man. Frenchy was giving me **** the other day for having 3" pipes on my Kota and losing out on TQ. After all my mods, my truck jumps when I command it too. Of course lots of variables involved such as fuel type used and even air temp, but I would not do anything else to my Kota except go extremes and port/polish, S/C types. But why do that to a daily driver. To prove a point, I average 18.8 mpg in 116deg AZ weather w/85oct during the summer. Even better mpg in the winter.
I've never even SEEN 85 oct fuel. What's up with that?
Old Dec 12, 2007 | 12:44 AM
turbot_bird's Avatar
turbot_bird
underdrive pullys spin the accesorys such as A/C and alternater slower puting les drag on the motor
Old Dec 12, 2007 | 08:44 AM
Dusty's Avatar
Dusty
I remember reading that 27 ft/lb claim back when these were back ordered/couldn't order one. Doesn't that torque gain sound optimistic to anyone else? [&:]
Either way to those who got one- is the big harmonic dampener still on the pulley? Is it significantly lighter? We were going to build some out of aluminum, but were alittle worried about harmonics...
Old Dec 12, 2007 | 11:30 AM
cramerica's Avatar
cramerica
The 4.7 pulley should be a direct bolt on for the 3.7L as well, correct? The serpentine belt on my truck says 3.7/4.7, and I've heard that the front of the motors are the same.
Anything around 20 FT-LB for a 3.7 engine would be huge! 255 FT-LB, thats starting to sound respectable.
***EDIT***
I see that P/N 501150 can be used for 99-03 Ram 3.7L's, so I'm taking that as a 'yes' for us 3.7 Dakota guys too.
Old Dec 12, 2007 | 01:25 PM
turbot_bird
ORIGINAL: Dusty
I wouldnt mess with the balencer unless you where going to have the crank balenced.
Old Dec 12, 2007 | 10:10 PM
Dusty's Avatar
Dusty
ORIGINAL: turbot_bird
ORIGINAL: Dusty
Are these motors not internally balanced?
