Fog/Running lights
My baby is 2006 Dak ST I want to put in the fog lights like the SLT. Has anyone done this and is the cutting difficult and are the mounting holes etc already in the ST bumper. Any info apprecieated. Possibly part # of light system to buy also.
Thanks
T
Thanks
T
if you're buying an OEM kit you should have to cut anything, the fog light holes are just covered by inserts that i believe pop out. I had projector fog lamps for a while but had to drill a few holes in the bottom of the mount area, which was stupid.
To insert the fog lights, you will have a little bit of a problem there because of diameter issues...just shove until they're in, and then position them to where the screw holes line up with the mounts behind the bumper. You will have 2 screws per side, and once you're done with that all you have to do is the wiring, which I believe will already be there.
mine didnt pop out. i took the bumper right off, its only 6 torques screws and used a demel and the holes look clean. and for the actual lights i just bought a pair of OEM's off ebay. and with that bumper out of there the lights went right it and running the wires was simple. when its gets nicer out i can get some pics of it for ya if you want
these arethe ones a bought. the only problem is that they dont come with the factory switch
http://cgi.ebay.com/ebaymotors/05-06...spagenameZWDVW
and here a is set that comes woth a factory switch
http://cgi.ebay.com/ebaymotors/05-07...spagenameZWDVW
hope it helps
hope it helps
I've had my eye on the ones with the switch on EBAY but was not sure if they were correct. Thanks
