Looking at wheels, will these work?
Old Dec 28, 2007 | 01:48 PM
BrandonMiller's Avatar
BrandonMiller
Default Looking at wheels, will these work?
http://www.centerlinewheels.com/whee...&sw_id=300
I can't stand the stock steel wheels..
I'll probably stick with the stock tires for now since they are new. BTW I just filled my second tank of gas - 13mpg, eeeek!!
Wheel Size Rear Spacing Offset Bolt Circle
16 x 8 4.5" 0mm 5-5.5" dodge, early ford trucks 5-lug
Old Dec 28, 2007 | 05:51 PM
BrandonMiller
Default RE: Looking at wheels, will these work?
well I keep finding different numbers for the offset on the stock steel wheel, I pulled the trigger so I hope they don't look too funky. If the stock is 5.5" backspace and 7" wide than my 4.5" backspace and 8" wide is gonna stick out 3" more than stock, eek..
[8D]
Talking to myself here.. looks like stock has a 20mm+ offset so that pushes it out and since the ones I just bought have a 0 as long as I don't have caliper clearance issues then that helps a bit
