Brakes
Old Jan 4, 2008 | 08:29 AM
MonkeyWrench4000's Avatar
MonkeyWrench4000
Default Brakes
When did you all need to change your fronts? I have 25k miles on the truck now, and sometimes I feel like its starting to skate to a stop. I know the truck is pretty heavy. To lazy to pull a wheel off and check.
Old Jan 4, 2008 | 08:33 AM
AdidasCJ's Avatar
AdidasCJ
Default RE: Brakes
mine has about 30k and my rotors are warped.... the front end of this truck just seems to have its issues....
Old Jan 4, 2008 | 10:35 AM
mplue's Avatar
mplue
Default RE: Brakes
I must be easy on my brakes. I have almost 65k and they are still feeling pretty good. I'll probably change them this summer when I replace my tires.
Old Jan 5, 2008 | 10:43 AM
pack154's Avatar
pack154
Default RE: Brakes
ORIGINAL: MonkeyWrench4000
I changed both my brakes and rotors at 30k due to the rotors being warped. I put on slotted and drilled rotors and they work really good.
Did you figure out your steering column?
Old Jan 5, 2008 | 02:32 PM
superdak05's Avatar
superdak05
Default RE: Brakes
i am almost at 50000 miles and have never had a problem. still using the factory stuff
Old Jan 5, 2008 | 03:01 PM
pack154's Avatar
pack154
Default RE: Brakes
I had plenty left on the pads but the rotors were terrible, so I just changed out both. The braking is soooo much better!!!
They must have given you the good stuff.
Old Jan 8, 2008 | 12:38 PM
Nicegy525's Avatar
Nicegy525
Default RE: Brakes
all modern day pads come with "squealers" a little metal prong that starts to scrape your rotors when the pad gets low. It makes a squealing noise to tell you its time to replace the pads. roll down the window, turn off the radio and take a listen next time and see if its making a noise. best way to check however is pull off a wheel and check the pads.
