Front struts options for the Dakota
Old Mar 20, 2008 | 09:16 PM
  #81
mudbug's Avatar
mudbug
Default RE: Project Wrap up; Front struts options for the Dakota
I found this check it out. http://www.rockauto.com/dbphp/prt,904,71111
Old Mar 20, 2008 | 11:20 PM
  #82
DD064x4QC's Avatar
DD064x4QC
that looks like the right one but do they really sell it is the question???????????
Old Mar 22, 2008 | 06:58 AM
  #83
Dak_in_Black's Avatar
Dak_in_Black
The p/n for the Monroe is 71100...
Monroe does not give a date
Rockauto says "Non-stock item--shipping delayed up to 51 business days"
Shockwarehouse "71100 Monroe Sensatrac / New part available June 2008."
So, nothing yet....
Old Mar 22, 2008 | 11:35 AM
  #84
turbot_bird's Avatar
turbot_bird
I was also hoping that this would work......
Old Mar 22, 2008 | 04:34 PM
  #85
rookie's Avatar
rookie
stuffing an assembly that is three inches longer would be pretty tuff. I had trouble getting the strut w/ the TM spacer back in place. I had to compress it a bit and clearance the LCA w/ a grinder. And that was for an assembly that was probably less than 21" long.
Old Mar 22, 2008 | 04:42 PM
  #86
rookie's Avatar
rookie
first, how much were those struts that your eating? second, is it possible to compress them enough to get them to bolt on?
Old Mar 24, 2008 | 10:29 PM
  #87
djsilver's Avatar
djsilver
ORIGINAL: rookie
I spent $185 including shipping. While trying to disassemble one for measurements, I spent about 3hrs with rust-buster, a heat gun and finally a propane torch trying to get the rusted nut off the top and finally broke the hex nipple and had to drill out the end of the strut rod to get it apart.
When I was trying to install it, I had the spring compressed enough that I had the pre-load off the perches and could spin the spring freely. These springs are about 500lbs/in so you can see in the picture that my spring compressors were under enough tension that the rods are visibly bent. I have a second, older set of spring compressors and I may have been able to compress them further with both sets tightened up but even if I got them on there I couldn't have gotten the upper A-arm back on because of spring interference and if I got past that, there would likely be zero droop in the suspension and droop is very important for ride-quality.
To the other poster about the Monroe struts; I stand corrected and 71100 is the correct p/n for the Dakota.
Old Apr 1, 2008 | 09:43 PM
  #88
rookie's Avatar
rookie
thanx very much for all the R&D. Hope i can contribute somewhere along the line.
Old Apr 1, 2008 | 09:54 PM
  #89
djsilver's Avatar
djsilver
I haven't given completely up on this but haven't made any more progress either. I'll let you guys know if I ever figure anything out.
Old Apr 2, 2008 | 02:07 AM
  #90
turbot_bird
Is there a way to take the upper mounts and swap them from a ram? Do they bolt to the frame or are they welded? I keep forgetting to look at mine....
