CD Player
Old Feb 22, 2008 | 06:02 PM
Luke979's Avatar
Luke979
Default CD Player
Hello,
I've been reading for a while, but have yet to post. I have a 2005 Dakota, 4.7 extended cab.
Has anyone had any issues with their cd players? It has the single disc player, and it will not eject a cd. I don't use the cd player that much and this is the first time it has happened. When I push the eject button it makes a little noise but that's it. The cd will play some, but the mode button to turn on the cd player doesn't always seem to work either. It had worked fine up until this point.I was going to poke around in the cd deck but you can't really see in there and I don't know what all is in there. Anyone know any simple fixes? I don't really want to take the radio out or take it in to the dealer again, but that may be the only option. Thanks for your help.
Luke
Old Feb 22, 2008 | 06:29 PM
Luke979's Avatar
Luke979
Default RE: CD Player
Thanks for the reply. I will probably be trying that tomorrow when this happens again. I just pushed the eject button again, and for whatever reason the cd came out. I really doubt this will be the last time it happens though. Guess I'll just have to be careful with which cd's I put in there.
Old Mar 11, 2008 | 02:38 PM
king beer's Avatar
king beer
ORIGINAL: Luke979
Yes.My single disc cd player will cut out the sound on the right side for an instantand then come back to normal volume (about 17-20ish) from both sides. It's almost as if someone is muting it and un-muting it almost simultaneously. Very annoying. Bought the truckbrand new and it's done it since day 1.. I should get that looked at beerfore my warranty runs out...
Old Mar 11, 2008 | 05:16 PM
lowcountrykid's Avatar
lowcountrykid
i have the 6 disc changer and i had problems with it cuz it wouldnt even take the cd's and i took it back and the dealership took it back and they changed it out ..
Old Mar 11, 2008 | 10:39 PM
LB's Avatar
LB
My changer went out last month, and dodge replaced it. They said the factory will extract the cd's and mail them to me.
It was strange because I came home one night and all was well. the next morning the truck would not start due to run down battery. I charged it, started it and let it run for a while. Later I had to get something out of it and noticed the changer was constantly switching between cd's, no key in the ignigion or anything. then it quit and it did'nt even reconize a cd function! Anyway I hope I ger my kid Rock CD's back soon!
LB
Old Jan 19, 2015 | 09:05 PM
sawfish's Avatar
sawfish
Originally Posted by ericemery
Well, you can "reset" the cd player by pulling the fuse, turning the truck on and waiting 20 seconds...
Turn it off and put the fuse back in. That is a reset that sets it back to factory specs. Try that first. if not, the off to the dealer I guess.
Is this an under dash fuse, or is it in the fuse block under the hood? Thanks.
Old Jan 19, 2015 | 11:54 PM
isolated1523's Avatar
isolated1523
Worst case scenario, I've got a stock one that I just pulled out of my truck that'll I'll let go for cheap.
-Adam
Old Jan 20, 2015 | 12:14 PM
That post was from 7 years ago.....check both places and see where it is.
