Lift block questions
Old Mar 1, 2008 | 10:43 AM
MonkeyWrench4000's Avatar
MonkeyWrench4000
Default RE: Lift block questions
The reason you cant find them is because they only come with the lift kit. Its under the Leveling kit section, and you can add the rear blocks and shocks as a package. The only way you can get JUST the shocks is to call them, and let them know. its going to be worth it.
Old Mar 1, 2008 | 12:19 PM
Jadman's Avatar
Jadman
No 4WD Kits, I don't get it.
Old Mar 1, 2008 | 12:56 PM
Cadillac15's Avatar
Cadillac15
Will the shocks work even though my truck is 4wd?
Old Mar 1, 2008 | 03:27 PM
MonkeyWrench4000
Yeah the shocks are for the rear, of course they will work. doesnt matter if its 4wd or 2wd. The rear end is no different. It doesnt matter if the kit is for 2wd, you dont want the kit, you just want the shocks, but you have to call and let them know the deal so you can just buy the shocks only. These shocks are the ONLY longer shocks you can find that fit the rear end of the dakota for the 2" lift you will be putting on.
You dont need them, its just a good idea with the 2" blocks.
Old Mar 1, 2008 | 03:33 PM
Cadillac15's Avatar
Cadillac15
Thanks MW (not sure what your actual name is). I appreciate the help Ill be ordering a set later this week.
