Stiff suspension questions
Old Mar 16, 2008 | 04:16 PM
reitman's Avatar
reitman
Default Stiff suspension questions
I just got my 05 quad cab and I noticed pretty quickly that it does not handle bumps in the road very well. The truck is 4.7 with 25k on it.
It seems like when you hit a bump, the rear end hops and moves laterally. It happens at most speeds and is very unnerving at hwy speeds.
Would swapping in some high quality shocks help out with this?
I've been doing some searching and reading, but can't really come up with an answer.
Thanks,
Sean
Old Mar 16, 2008 | 05:53 PM
Frenchy's Avatar
Frenchy
Default RE: Stiff suspension questions
Well, good luck finding any...
Old Mar 16, 2008 | 09:06 PM
turbot_bird's Avatar
turbot_bird
All pickups jump in the back when hitting bumps. they are too light in the back. Our suspention is real soft too making the truck bounce uncontroably.
Old Mar 16, 2008 | 09:41 PM
BAdassR/T's Avatar
BAdassR/T
all these dakotas do that its horrible i must say dodge put in 1 dollar suspension in our trucks bc it straight up blows
Old Mar 16, 2008 | 11:16 PM
djsilver's Avatar
djsilver
It bounces because it's underdamped and not because the springs are too soft. Replacement rear shocks are available that should help with the problem (Monroe Reflex #911277 or Rancho RS5313)
I'll be changing mine but I'm waiting until if decide what to do about the front first. Monroe lists a part #71111 for the Dakota but it's not available for sale yet.
Old Mar 17, 2008 | 12:44 PM
reitman's Avatar
reitman
I think I will swap out the rear ones right away and see if that helps any. Thanks for the replies so far.
Sean
Old Mar 17, 2008 | 07:50 PM
jtw111's Avatar
jtw111
Also watch the front end around 35000, the ball joints get a bit shakey. Haven't really given the rear end much thought after fixin up the front for inspection purposes. Would be nice to have about 750 more in the read to hold baby down. Good luck in your search, I am anxious to see if there is a good fix for our problem.
