leveling kit and tires....
hey guys... I'm looking to start modding my '07 Dakota and i have decided to start with a leveling kit. It seems most people prefer the TM kit, but what are your opinions on the CCM kit? I will also be replacing my stock alloy wheels with some 16 in. black steelies. Will i be able to run 32's with out rubbing? And finally, i am looking for the nose up prerunner look, could i run the rear lowering shackles with these larger tires? Thanks alot.
i believe the ccm goes on top of the strut . thus when fully extended the cv joint can bind. i think the tm inside the strut is the way to go. use the new instructions on the web site. although if you have a 2wd ignore everything go with either.
