Help! Vibration Issues with my truck
Just wondering if anyone elso has had vibration issues with their 05-07 Dakota 4x4? My 06 Quad cab has a shake starting at 60 K/hr that I can't get rid of. Been back to the dealer 4 times for the same thing. They have no idea what it is. Tires and rimes have all been changed and no difference. Any Advice? No Lemon Law here in Canada. Arrrggghhhh.
Guest
Posts: n/a
the brakes on these trucks have been known to cause vibration at highway speeds... I believe there was a TSB regarding it...
thats all I can think of aside from tires/wheels or maybe an imbalanced engine...
We had a new Ford Excursion a few years back that had a very similar sounding issue, and after going though all the similar first thought items like tires and wheels, and even rear axle, they fianlly found it, the drive shaft was out of ballance, they replaced the drive shaft and that took care of it.
did you have the TSB done? There is a TSB out on the 05-07 Daks because of the rear brakes. The TSB makes the dealer change the drums and shoes as well other items on the rear at no charge. This happened to my '06. So far so good on my '07 (knock on wood).
ORIGINAL: SilverGhost1
Guest
Posts: n/a
