Throttle Spacer for V6
Old Jul 2, 2008 | 09:10 AM
wyattc329's Avatar
wyattc329
Default Throttle Spacer for V6
I hate aftermarket companies... they really only make crap for the V8.... how different is the Liberty V6 from the Dakota... because they make spacers and intakes for the Liberty.... My knowledge is it is the exact motor, but is anything else in the engine going to prevent me from being able to use liberty parts?
Old Jul 2, 2008 | 10:28 AM
SilverGhost1's Avatar
SilverGhost1
Default RE: Throttle Spacer for V6
I think it is the exact same engine. I don't know of anything different on it that would make it such. See below what I pulled off of Allpar.com.
Here are the specs for the V-6 of the Liberty;
[ul][*] ENGINE: 3.7-LITER, OHV, 16-VALVE SMPI POWER TECH V-6 Availability Standard – Renegade and Limited Edition, Optional – Sport Type and Description Six-cylinder, 90º V, liquid-cooled Displacement 225 cu. in. (3701 cu. cm)[*]Bore x Stroke 3.66 x 3.57 (93 x 91)[*]Valve System Chain drive, SOHC, 12 valves, roller followers with hydraulic lash adjustment Fuel Injection Multi-point fuel injection with returnless fuel rail[*]Construction Cast-iron block, compacted graphite bedplate, aluminum cylinder head[*]Compression Ratio 9.1:1[*]Power (SAE net) 210 hp (157 kW) @ 5200 rpm[*]Torque (SAE net) 235 lb.-ft. (319 N•m) @ 4000 rpm Max.[*]Engine Speed 6000 RPM, electronically limited[*] Fuel Requirement Regular unleaded, 87 octane (R+M)/2[*]Oil Capacity 5 qt. (4.7-Liter) Coolant Capacity 14 qt. (13-Liter)[*] Emission Controls Catalytic converters, oxygen sensors, on-board vapor recovery system, leak detection pump system(a)[*] Max. Gross Trailer Weight (lbs.) Automatic with trailer tow package 5000 lbs. (2250 kg)[*] Manual transmission 3500 lbs. (1600 kg) EPA Fuel Economy (City/Hwy) Automatic 17/21 / Manual 16/22 [/ul][ul][*]Meets Federal Interim Tier 2 B in 9A standards and is a California ULEV I under California Cleanest Vehicle Rules in CA, NY, MA, ME and VT.[/ul]
And here are the specs for the Dakota V6;
3.7-LITER SOHC V6 [ul][*] Displacement: 226 cu. in. (3701 cu. cm)[*] Bore x Stroke: 3.66 x 3.57 (93.0 x 90.8)[*] Valve System: Chain-driven SOHC, 12 valves, hydraulic end-pivot roller rockers[*] Fuel Injection: Sequential, multi-port, electronic, returnless[*]Construction: Cast-iron block and bedplate, aluminum alloy heads, balance shaft. 90 degree V6.[*] Compression Ratio: 9.7:1[*] Power (estimated SAE net): 210 bhp (157 kW) @ 5200 rpm[*] Torque (estimated SAE net): 235 lb.-ft. (319 N•m) @ 3600 rpm[*] Max. Engine Speed: 6000 rpm (electronically limited)[*] Fuel Requirement: Unleaded regular, 87 octane (R + M)/2[*] Emission Controls: Dual three-way catalytic converters, heated oxygen sensors, and internal engine features[*]EPA mpg (City/Hwy): [ul][*]2WD: 16/22 — manual trans., 17/22 — auto. trans.[*]4WD: 16/20 — manual trans., 15/19 — auto. trans. [/ul] [/ul]
Old Jul 2, 2008 | 12:55 PM
wyattc329's Avatar
wyattc329
I've been in contact with a tech from Airaid. This is what I've gotten so far....
Hello,
What year Dakota and what year liberty?
For the 2007 model year with the 3.7L, the same spacer will work.
Thanks,
I'm awaiting comformation for the 2006.
Old Jul 2, 2008 | 09:29 PM
Altair's Avatar
Altair
Dak attack!
Get an intake, save your money and pick up a Fastman throttle body, the spacers are worthless on our trucks.
Old Jul 2, 2008 | 11:59 PM
wyattc329's Avatar
wyattc329
I have already planned on ordering a Cold Air Intake, but something about the throttle spacer has always appealed to me, since I've had them on every truck I've owned lol.
I got an email back from the tech at AirRaid and the 2006 version of the dakota and liberty do not work. (Retarded, I don't see much change between 06-07) So that ends that I guess.
Old Jul 12, 2008 | 12:12 PM
T ReX's Avatar
T ReX
Junior Member
Let me know what kind of intake you go with been looking for one for my 07 mighty 6 but cant seem to find any except airaid which is fine but would like more options.
