First Sig
Hi!!
Well, yes PSD are not supported on most web servers, it would be perfect if you can export your work to .JPG format, in order to do that just look on the file menu for save as command, or export command, and on the next window just choose on the filetype box the .JPEG or .JPG format. You will also be able to choose quality, 100% is really big so 70 to 80 % may be suitable for the web. Also on Photoshop inside the file menu you will find publish for the web command, that is also suitable to do this work.
Hope to see your work soon.
Rayzuli.
Rayzuli.
