iput the upper ball joint back together after installing the spacer and found that after i tightenend the nut there is still space between the knuckle and the flange on the ball joint. i know that the ball joint is tapered but should the flange be against the knuckle? the flange is more noticable because i tore the dust boot to pieces with a pickle fork.
