Shock options - current status?
Old Sep 17, 2008 | 03:01 PM
MonkeyWrench4000's Avatar
MonkeyWrench4000
Thumbs up
Originally Posted by RonnusTwo
NOW - as for installing them yourself - per my mechanic they were an extreme PITA to install. Not the rears - just the fronts. Apparently the heads of the bolts that mount thru the top of the shock(which weren't long enough I assume due to my TM level kit) cannot be reached to tighten them when in place, so they needed to be welded in so they dont spin while tightening. Now I don't know if this was a problem was caused by my mechanic or if everyone will find this probem, so keep that in mind.
But overall they're in and they're grrrrrrrreat!
My mechanic did the exact same thing when I had my TM kit removed. I have new bolts welded into place.
Old Sep 17, 2008 | 04:24 PM
MonkeyWrench4000
May be a silly question, but since monroe now makes our struts, do they make the quick struts? I would rather replace the whole assembly, with new springs in all, quick and easy.
Old Sep 17, 2008 | 08:51 PM
sawfish's Avatar
sawfish
You can do that, if they make them, but you will not have the TM leveling kit, which caused the problem (modification) in the first place.
Old Sep 17, 2008 | 10:16 PM
MonkeyWrench4000
I havnt had the TM kit installed in a long time. I am stock. I think I am just going to call my dealer and try to get them to replace my struts before I am out of warranty. It's crazy to pay for struts after only 32k miles. At least I can get another 2 years out of the new factory struts before I have to dip into my pocket for the ranchos...
Old Sep 18, 2008 | 08:33 AM
studlyblueiz's Avatar
studlyblueiz
That seems just a hair over retarded. If Rancho's shocks need alterations to help make it installed and work then they should fix it. Has anyone said anything to Rancho? You should be ticked you paid a mechanic extra labor to craft that thing in there. I wouldn't pay for a mechanic to change it out, personally, but if I got to the point of removing mine and put the Rancho up there I'd be pissed. Especially, if I needed to pull out a welder.
Old Sep 18, 2008 | 09:01 AM
RonnusTwo's Avatar
RonnusTwo
Actually I'm pretty sure the blame falls more within Dodge design than with Rancho.
The shock itself needed no modifications to mount, however the design of the truck doesn't allow you to get to the bolts of the upper shock-mount. My guess is that even the dealership would need to do the same thing with factory shocks, which btw have already proven to be garbage.
I wish I had a better explanation of the "upper shock-mount" but I have no idea what it's called - maybe upper control arm?? I did see it for myself after I thought my mechanic was trying to screw me, but the truth is you simply cannot get to the bolt heads to tighten them once the shock is in place.
Old Sep 18, 2008 | 10:51 AM
MonkeyWrench4000
It has nothing to do with rancho, even getting new struts at the dealer will have the same problem.
Let me explain...
You know how the top of the strut assembly bolts to the truck with 3 small bolts? Those bolts are sticking out of the top plate of the strut, so you slide the strut into place and bolt them down. The only problem is, that they will spin as you try to bolt them down. So when this happens, our mechanics got around it by taking the strut top plate off the assembly, and spot welding each bolt head to the top plate, putting the top plate back on the strut, slide the strut in and boom it mounts right up.
I will show you a pic....monroe's website calls for a replacement of that plate when they do the struts with there monroe struts...
http://catalog.tenneco.com/monroe/pr...catalog=MONROE
This picture is off there site, its called the "strut mate bearing plate" and thats whats on top of your strut when you remove it and look at it. See how the bolts stick out on top? well when this plate is on the strut, there is no way to get to the heads of the bolts to prevent them from spinning.
This picture actually shows the replacment monroe uses when doing a strut change, and it looks a little different. It looks like the bolts won't spin on this one. Thats why they replace it.
So, our mechanics simply spot welded them so they wouldnt move. It's not a big deal at all....just built poorly.
Old Sep 18, 2008 | 01:12 PM
studlyblueiz
Then that just means Dodge was retarded on the entire front suspension.
Old Sep 18, 2008 | 03:06 PM
MonkeyWrench4000
I can't understand for the life of me why they would do away with the Torsion bar setup and go with this 2wd setup accross the entire line. Its madness...
Old Sep 18, 2008 | 10:59 PM
NJJer's Avatar
NJJer
I have Bilsteins on the back of my 05. Love them!
