If my memory serves me correctly, it was all internals, ie cams, pistons, etc, higher compression and a different intake manifold. I may have missed somethings...
i think its just cams and compression (pistons). when i bought my truck, i had the parts guys look up the intake maniold for the ho. they said the intakes are the same from 05+ i think. the older 4.7 did have intake difference between the 2, but i guess not now.
joe, you have. better flowing fuel injecters, a different bottom end. better flowing heads and cams. pcm is different also. go to www.allpar.com and look at the engine specs for both. there not that far from each other. only thing you would need to do when you supercharge, is to double up an the head gaskets. everything else will hold together with 8 to 10 lbs of boost
trucks great, everytime we get ready to goto the track it rains. we were suppose to goto lebanon valley dragway this weekend for mopars in the valley but was rained out
no its not an sts its another kit not sure wtf he got, but suppose to have 500hp to wheels at 3psi and u know were not running 3psi were def gonna run 5 or 6, ooooooooooooooooooooooooo man can wait its getting installed on Wednesday
