Rough idle still.
Old Nov 4, 2008 | 04:41 PM
  #21
JHAAF's Avatar
JHAAF
Default ?
Anymore suggestions? It does seem to be a little better. It may just be in my head though. Idle still is bumbling some. No wonder they are wanting to merge or sell to the bow-tie company. Not a chevy fan but, never hear of all these troubles with them.
Old Nov 4, 2008 | 07:27 PM
  #23
lghtngblt02's Avatar
lghtngblt02
The RAM Administrator
There are troubles on the Chevy side too...My parents own em well half now ... My mother ended up ditching her Colorado for a PT because of all the problems they were having with the rear door latches, my dads Silverado has a tendency to lock in park occasionally or not shift out of 3rd due to some connector that keeps attractiing moisture and requires the computer to be reset....problems are out there. Just look for em I am not saying the Daks are problem free, they are just like any other vehicle.
Old Nov 4, 2008 | 08:35 PM
  #24
JHAAF's Avatar
JHAAF
I have owned several makes and i will say have never seen any of these problems before. The way everyone else on here has the same problems tells me about these vehicles. May just get tire and dump this off to the next sucker. I am wondering if i am not caught up in the valve job recall. I have seen some of the replies on here were they had the job supposedly done and it still is crap.
Old Nov 4, 2008 | 09:00 PM
  #25
varsis's Avatar
varsis
ever try seafoam guys?
Old Nov 5, 2008 | 08:01 AM
  #27
x99j's Avatar
x99j
before you go all doom and gloom. look what i found! if you have good plugs, a clean throttle body and good compression it is normal and here is why thanks to wikapedia! the 3.7L is even mentioned in the article! mike
well according to wikapedia the 3.7 is an odd fire v-6 with a three pin crank shaft making it a odd fire v-6. the lack of a split pin crank makes the rough idle. you can read about it in the cut and paste below! mike
Link in full:
http://en.wikipedia.org/wiki/V6_engine
90 degrees
90-degree V6 engines are also produced, usually so they can use the same production-line tooling set up to produce V8 engines (which normally have a 90-degree V angle). Although it is relatively easy to derive a 90-degree V6 from an existing V8 design by simply cutting two cylinders off the engine, this tends to make it wider and more vibration-prone than a 60-degree V6. The design was first used by Buick when it introduced its 198 CID Fireball V6 as the standard engine in the 1962 Special. Other examples include the Maserati V6 used in the Citroën SM, the PRV V6, Chevrolet's 4.3 L Vortec 4300 and Chrysler's 3.9 L (238 CID) Magnum V6 and 3.7 L (226 CID) PowerTech V6. The Buick V6 was notable because it introduced the concept of uneven firing, as a result of using the 90 degree V8 cylinder angle without adjusting the crankshaft design for the V6 configuration. These engines were often referred to by mechanics as "shakers," due to the tendency of the engine to bounce around at idle speed. More modern 90-degree V6 engine designs avoid these vibration problems by using crankshafts with offset split crankpins to make the firing intervals even, and often add balancing shafts to eliminate the other vibration problems. An example is the 90-degree Mercedes-Benz V6 which, although designed to be built on the same assembly lines as the V8, uses split crankpins, a counter-rotating balancing shaft, and careful acoustic design to make it as smooth and quiet as the inline-6 it replaced.
[edit] Other angles
Narrower angle V6 engines are very compact but can suffer from severe vibration problems unless very carefully designed. Notable V6 bank angles include:
[edit] Odd and even firing
Many older V6 engines were based on V8 engine designs, without altering the V angle or using a more sophisticated crankshaft to even out the firing interval. One characteristic of these engines was a notorious odd-firing behavior.
Purpose-built V6 engines use one crankpin per cylinder for an even 120° ignition pattern. In contrast, most V8 engines share a common crankpin between opposite cylinders in each bank. That is, the crankshaft has just four pins for eight cylinders, and a cylinder fires every 90° for smooth operation.
V6 engines derived from V8 engines often have three shared crankpins arranged at 120° from each other, similar to an inline 3-cylinder, with two pistons per crankpin. If the cylinder banks are arranged at 90° (as they commonly are in V8-derived V6s), this leads to a firing pattern with groups of two cylinders separated by 90° of rotation, and groups separated by 150° of rotation.
An example is the Buick 231 odd-fire, which has a firing order 1-6-5-4-3-2. As the crankshaft is rotated through the 720° required for all cylinders to fire, the following events occur on 30° boundaries:
Angle 0° 90° 180° 270° 360° 450° 540° 630°
Odd firing 1 6 5 4 3 2
Even firing 1 6 5 4 3 2
Nissan uses the firing order 1-2-3-4-5-6 in some of the V6 engines they make.
In 1977, Buick introduced a new "split-pin crankshaft" in the 231. Using a crankpin that is 'split' and offset by 30° of rotation resulted in smooth, even firing every 120°. However, in 1978 Chevrolet introduced a 90° 200/229 V6, which had a compromise 'semi-even firing' design using a crankpin that was offset by only 18°. This resulted in cylinders firing at 108° and 132°, which had the advantage of reducing vibrations to a more acceptable level and did not require strengthening the crankshaft. In 1985 Chevrolet's 4.3 (later the Vortec 4300) changed it to a true even-firing V6 with a 30° offset, requiring larger crank journals to make them adequately strong.
SURE WISH THE DEALER COULD HAVE EXPLAINED THIS? BUT I GUESS MONEY IS MORE IMPORTANT THAN REPEAT BUSINESS?
Old Nov 5, 2008 | 12:02 PM
  #28
Jaded's Avatar
Jaded
It's like the Harley of pickups then? Shakes, vibrates, old tech engine.
Old Jan 31, 2020 | 10:40 PM
  #29
Bearbrand's Avatar
Bearbrand
I have a KJ Cherokee (Liberty in USA) with the same engine and problem of high tps voltage but sensor seems to be reading correctly when throttle is opened. Looks like there may be a warp in the shaft running from the throttle body to the tps. I have given that a tweak and now reading about .35V instead of .65V at idle. Still getting the engine warning light coming on. Will try and tweak it down to .29V as suggested by JHAAF.
