Regarding headlights
Guest
Posts: n/a
well, I dont have many pics of the install... not much to really see...
eric thanks for the help what hid kit did you get? This kit says its just a simple plug in setup.http://www.xenonking.com/Visionpro-3...d-Kit-Car.html What size is the best to get? Can't wait to get it.
sorry for all the questions i'm kinda getting what your saying. the relay is needed for the ammount of watts put out so it doesn't fry the wiring? how is the relay installed and where? lol i feel stupid
The most basic way to look at it is the relay is a switch. It's connected to your stock lighting harness, your battery, and the new HID's. When it sees power on the stock harness (i.e. when you turn the headlight switch on) it connects the battery and the HID's. This way they are powered from the battery instead of through the stock harness but you control them with the normal headlight switch.
Very good description altair
06 heres a more in depth look at relays if you are curious. http://en.wikipedia.org/wiki/Relay
