Iridium plug update
Old 11-07-2008, 11:43 AM
coondog05's Avatar
coondog05
coondog05 is offline
put the irids in....mines non H.O... and the plugs are way impressive!
read up on this thread!
  #22
Old 11-07-2008, 03:08 PM
SilverGhost1's Avatar
SilverGhost1
SilverGhost1 is offline
How is your MPG with the Iridiums?
  #23
Old 11-08-2008, 11:10 AM
coondog05's Avatar
coondog05
hahaha! ur kiddin right! well its still bad! 250-260 to a tankfull..... but it hasnt really changed from the switch...foots been in it a bit more so maybe it will be a mile or so better im thinkin....switch em.... it wont be worse!
  #24
Old 11-08-2008, 11:57 AM
blkmagic's Avatar
blkmagic
blkmagic is offline
What's the plug number that you got? Checked one site, 2 listings for 4.7, 2 different plug number for each listing but don't give which is 4.7 and which is 4.7HO...different gap also, .035 and .044.
  #25
Old 11-08-2008, 03:48 PM
SilverGhost1
3923s are in. There is not even a comparison to the 5224s I put in before my trip to CA. They were great for the highway, but absolutely sucked in local traffic. So, the 3923s are in and since I had experience with my last Dak with them, I know they will perform nicely.
  #26
Old 11-08-2008, 04:19 PM
coondog05's Avatar
coondog05
plug # is 6441 and there gap is .44 they come pre gaped but if you check em like i allways do...be carful cause the electrode is thin as a pin!
  #27
Old 11-09-2008, 11:14 AM
Jaded's Avatar
Jaded
Jaded is offline
Anyone try bosch 4508 IR fusions? Thinking of going with those since theres a rebate going on.
  #28
Old 11-10-2008, 09:28 AM
fireman2828's Avatar
fireman2828
fireman2828 is offline
  #29
Old 11-12-2008, 03:44 PM
sawfish's Avatar
sawfish
sawfish is offline
Default Champion Platinums
I read about the improved performance and mileage with the Iridium and Autolite plugs, but I had already bought a set of Champion Platinum. Since I already had these, and did not want to pay $15 each for the NGK plugs, I installed the CPs at 39,000 miles. Mileage improved to 19.8 on the road (was 17.9-18.8 depending on conditions), and went up +1.5 in town. The truck also seems to have more power. Every one of the old plugs was gapped wrong. Possibly due to wear. New plugs were gapped at .040 and the old ones were gapped .045 to .050.
  #30
Old 11-13-2008, 09:07 PM
chad1972's Avatar
chad1972
chad1972 is offline
Default ngk
ive got 4.7 w/ sct tune and put reg.ngk vpower in after autolites and champ. runs perfect, smooth.easy start, very quick accelleration,even at 70 mph I gas it and it takes off, about 20 mpg hwy(easy cruising) 12-15 city.
Quick Reply: Iridium plug update
