airbag warning light
Old Jan 13, 2009 | 12:37 AM
  #31
sawfish's Avatar
sawfish
Angry
Is there a TSB on this issue?
Old Jan 14, 2009 | 06:32 PM
  #32
pojv's Avatar
pojv
I was taking in my 05 ( 22K) yesterday for the normal LOF and the dam airbag light came on, then off and on ect. So when I dropped it off I asked them to check for a code and let me know what is wrong. They called me a little later and stated that the sensor in the passenger seat needed adjusted, not covered under warranty or ext.- warranty $45.00. I said fine fix it and the light has been off all day today. There were not parts charged out on the job and the ro stated "Used weights to calibrate sensor"
Phil
Old Jan 14, 2009 | 08:06 PM
  #33
Jaded's Avatar
Jaded
My light came on 2 weeks ago with my wife in the pass seat, then disappeared after being shut off. At least theres a solution here.
Old Apr 14, 2009 | 02:26 PM
  #34
Jadman's Avatar
Jadman
I have had the same problems as of late. My Airbag light in the cluster along with the shifting quirk. Not really going to worry about either. I did fix one of the hoses under the radiator, it had a small leak. Others might want to look for the same leak.
Old Apr 14, 2009 | 02:38 PM
  #35
biker_ahoy's Avatar
biker_ahoy
Default leaking hose
I also had the same hose leak on mine, def an issue with the trucks, easy fix under warrenty
Old Apr 3, 2011 | 01:28 AM
  #36
jim501c's Avatar
jim501c
I have an 05 Magnum. The airbag warning light driver side has been repaired twice. After going on lineI discovered thisis a problem that Dodge has not adjusted too( CLOCKSPRING IN STEERING COLUMN). I was charged both times($300.00) for the same part 7 months apart. I can tell you this, both times the light came on when I was adjusting my steering colum. I suggest you only adjust the column with the ignition OFF. I also filed a complaint with NHTSA on line.
Old Apr 3, 2011 | 01:47 AM
  #37
cheeseburger's Avatar
cheeseburger
holy post in a 3 year old thread in the completely wrong subsection batman..............
