airbag warning light
Old Nov 12, 2008 | 05:25 PM
paul05dak's Avatar
paul05dak
Default airbag warning light
every once and a while (like just tonight) my airbag warning light likes to come on and stay on. After a couple of hours not running, it will go away. I'm wondering what could cause it and what happens if it doesn't go out later?
Old Nov 13, 2008 | 06:35 AM
sdsdsd's Avatar
sdsdsd
Could be that you have something very lite on the seat. Example laptop, breifcase, lunch etc. That will cause the airbag light to come on. When items are removed it will go out.
Old Nov 13, 2008 | 12:16 PM
paul05dak's Avatar
paul05dak
nope not it, then the seatbelt light would come on. not the airbag warning light in the speedo. Plus I had my son in the passenger seat with the belt on so that wouldn't be it.
I then went out a couple of hours later and started her up. no light. I just don't get it.
Old Nov 13, 2008 | 12:44 PM
Frenchy's Avatar
Frenchy
mine would do that if I forgot to plug the airbag light back in... maybe check that...
Old Nov 13, 2008 | 12:50 PM
cramerica's Avatar
cramerica
If I recall correcly, if the connection to the impact sensors in the front of the truck are bad or intermittent, the light will come on as well.
Old Nov 13, 2008 | 01:03 PM
RonnusTwo's Avatar
RonnusTwo
My passenger air bag-disabled light comes on every so often without anything on the passenger seat, and sometimes both the driver and passenger lights come on. usually they reset themselves after a restart or a couple of hours.
I have no idea why, and it seems to correct itself each time.
Old Nov 13, 2008 | 04:04 PM
cramerica's Avatar
cramerica
We're talking about the instrument cluster ABS light, correct?
Old Nov 13, 2008 | 05:26 PM
sawfish's Avatar
sawfish
Angry
I just started experiencing the same problem with my 2005. Both the dash light and the instrument cluster light will go on/off intermittently. You can lightly push on the front left corner of the passenger seat cushion and it will go off. Sometimes going over a bump will cause it to go off/on. Seems like a loose/faulty connection, but I have not traced it yet.
I had this same problem with the driver side airbag light (instrument cluster) a few months ago, and found that a rear floormat had worked its way under the seat. I moved it, and the light has not come back on, but have had no success with the passenger side. Any ideas?
Old Nov 13, 2008 | 05:54 PM
paul05dak's Avatar
paul05dak
the one in the instrument panel that looks like a guy in a seat, with seat belt and the airbag in their lap. It's red.
Old Nov 13, 2008 | 05:55 PM
paul05dak's Avatar
paul05dak
no ideas yet...
