change pcv valve
Old Nov 13, 2008 | 01:32 PM
bandito40's Avatar
bandito40
Default change pcv valve
Hi,
As my Dakota (2005 V8/Magnum) is used but new to me I am changing a few components so that way I know when a component was last changed. So far so good. The only problem I am having is replacing the pcv valve. I have located it on the front of the left cam cover where the oil filler cap is but I don't understand how to open the clip that holds it. Anyone know how this is done.
Thanks,
Bandito
Old Nov 13, 2008 | 08:51 PM
chad1972's Avatar
chad1972
I think you just twist is counterclockwise to get out,ill double check and get back tomorrow
Old Nov 13, 2008 | 09:17 PM
superdak05's Avatar
superdak05
pcv valve whats that? do you mean the egr valve? they are two different things
Old Nov 14, 2008 | 07:06 AM
coondog05's Avatar
coondog05
geeze mike.... he has the right location.... just push it in slightly and turn it. theres a oring so its a snug fit. might have to wiggle it some while turning too! hope this helps
Old Nov 14, 2008 | 09:28 AM
cramerica's Avatar
cramerica
PCV=Positive Crankcase Ventilation - allows gasses that blow by the pistons to evacuate the crankcase, and prevent oil loss.
EGR= Exhaust Gas Recirculation - a method of controlling combustion speed and temperature by introducing exhaust to the intake charge, to reduce NOx emissions.
Old Nov 14, 2008 | 12:05 PM
MonkeyWrench4000's Avatar
MonkeyWrench4000
Everyones a f*cking expert since google came around huh?
JK LOL
Old Nov 14, 2008 | 12:53 PM
cramerica's Avatar
cramerica
How dare you! Alright I did consult Wikipedia to make sure I wasn't wrong about the PCV.
