Mirrors
Yeah I havent look that detailed at my mirrors. I know what you are talking about the little waves... If thats the case with the heated mirrors than I may have them, cause the build sheet specifically calls out the tow mirrors
Yea I didn't realize it either. When I first saw the defrost I looked for the little wires on the back of my truck but i didn't have them so I looked all around and deduced that they had to be the mirrors. They worked well in PA. Had some ice and snow on the mirrors. So started the truck, hit defrost and scraped the wind shield, when i was done i looked and the ice had melted and fallen off
Guest
Posts: n/a
yeah guys, the rear defrost button turns on the tow mirrors... getting to the place that the mirrors plug in is pretty easy. a Phillips screw driver and about 4 screws get the door panel loose. pull it slightly up and out and you should be able to pull it off. just check to see if you have the harness up by where the mirrors are.
ok does everyone with the heated mirrors have the squiggly marks on there mirrors? I am gonna test my mirrors out tonight to see if they are heated. I dont have the waves, but I cant imagine having all the options except Nav and then the foldable mirrors having no heat... I have the heated rear window, so Ill let ya all know my findings
