finally lifting the DAK.... questions...
Old Jan 25, 2009 | 02:01 PM
flyboy1304's Avatar
flyboy1304
Default finally lifting the DAK.... questions...
Well guys its about that time... I finally decided that i'm gonna bite the bullet and go purchase the PA lift and the Level kit. I was trying to hold out till a real suspension lift was put on the market but the truck needs new tires anyways so I'll throw the lift on before i purchase tires. Here's a few few questions... Wheres the cheapest place to get the Level kit, and the PA lift? I'm also thinking of putting the ne shocks on it too. Whats the part # for those? also a good place to get those as well? and will 33's rub? I', thinking of just 32's. I'm wanting to keep the stock wheels, will there be problem with the back spacing on those? need advice! I but 33's on my Xterra and they rube'd alot. because of the wrong back spacing and i dont want that issue with my Dakota. thanks in advance... BTW i sold the xterra I shouldnt have wasted money on that and should have put it into the DAKOTA!
Old Jan 25, 2009 | 02:17 PM
flyboy1304's Avatar
flyboy1304
i found the part numbers...
Old Jan 27, 2009 | 12:33 AM
BrandonMiller's Avatar
BrandonMiller
you can fit 32's with just the leveling kit, but your going to need to trim the inner part of the fender flare. Post pics..
Old Jan 27, 2009 | 04:23 PM
themoneyshot's Avatar
themoneyshot
do you know if the fender flares remove those little mud flaps? thus allowing a bigger tire.
Old Jan 27, 2009 | 11:48 PM
donkeypunch's Avatar
donkeypunch
King Jackass
The Bushwacker flares delete the front mud flaps, just like the 08+ TRX4s.
