Light bar and four 6" lights installed
Old Feb 6, 2009 | 09:43 AM
donkeypunch's Avatar
donkeypunch
King Jackass
Default Light bar and four 6" lights installed
Finally, I came around to buying the off road lights for my light bar. I was planning on purchasing the Hella 500s...but I happen to stop by Harbor Freight...haha....can't beat $10.00 per light. I figure I would be replacing them with HID lights down the road anyway. The wiring is not done yet...that will happen this weekend. Can anyone post pictures of switch locations in the cab?
Old Feb 6, 2009 | 09:53 AM
snipingdude's Avatar
snipingdude
Wink
Looks excellent man...cant wait to see it with HID's in there lol....
Good Job!!!!!!!!!!....if i was you id just mount the switched near the current lamp switches..like right under them...jmo
Old Feb 6, 2009 | 10:00 AM
donkeypunch
King Jackass
Yeah, I would like to make it look as factory as possible. I have been considering using a carbon fiber plate to cover the small cubby hole next to the 4x4 switch.
Old Feb 6, 2009 | 10:24 AM
lghtngblt02's Avatar
lghtngblt02
The RAM Administrator
Looks snazzy... 10 bucks you cant beat that!
You must not have the airbag switch where you are planning on mounting the carbon fiber.
Do you have the center console?
Old Feb 6, 2009 | 10:42 AM
donkeypunch
King Jackass
Negative
Old Feb 6, 2009 | 01:06 PM
snipingdude
Oh one thing I wanna ask is...
do u plan on putting some grill guards on those?? I was looking at the side view pic for a min and i was like hmm those are asking for a crack lol
Old Feb 6, 2009 | 01:50 PM
paul05dak's Avatar
paul05dak
Here is where I put mine
I was thinking about the center console but 2 things stopped me. The possibility of spilling coffee on/in the switch and the additional PITA it would have been to do that.
Old Feb 6, 2009 | 01:55 PM
BAdassR/T's Avatar
BAdassR/T
looks good time to lift that truck!
Old Feb 6, 2009 | 02:09 PM
donkeypunch
King Jackass
Paul, that looks like a pretty good location. I might consider that. Did you use the switch to interupt the ground or power?
Eric, being that I build race cars I have access to carbon fiber, billet aluminum, 7 CNC machines and full service machine shop, moly tubing, TIG welders, MIG welders, and other various things...except regular looking plastic...haha.
Badass...I already have the TM 1.5" kit and 32" tires. I am an off-roading monger, so the body lift might be a consideration when I re-gear the truck for 33" tires. It does just fine with the 32"s on it, but I also tow the race car to the track...so I need a little help.
