Lifting a Dakota with dual spacers
I think I'm right in saying this. Due to suspension geometry, a 2" block would actually raise it approx. 2.75". I think the TM spacers are only 1.5" thick, but claim a 2" lift. From all I've read, going more than the TM lift on a 4x4 will kill the CV joints fast.
Thanks mprohr,
I know that the spacer that tm used to use inside the spring/strut setup and its a small spacer. I wanted to try and use two of those one on top and one on bottom, I am sure that tm has done the research and I figure I will just buy their kit and call it good. Just really frustrated with the aftermarket for these trucks.
Thanks mprohr,
Edit: Found it, it was made by Chassis-Tech and his posts about it are dated '05 so it seems they never released the kit. http://www.cardomain.com/ride/2115892
There is a 3rd gen dak on CarDomain that had a decent size suspension lift on it at one point....
Here is a slew of parts to raise our daks 4 inches. I know there has been a lot fo bad press on past lifts from these guys but I am looking at strictly the control arms for lift. No cradles or any of that. Just control arms springs and of course new cv drive lines.
EDIT: Forgot links, http://streetridepro.com/advanced_se...1&inc_subcat=1
If you're willing to risk it they might work well who knows just look around about them first, make sure you know what you're getting into.
A quick look at the truck and some notes I made, I think the front spacers are 2.25" thick or so. Maybe .25" more. Pretty sure 2.25 though
You CAN combine two leveling kits, IF you have a 2WD dakota. It has been done on this site, successfully. I don't know who it was but he has a black dakota and a black neon. He combined the trailmaster leveling kit, inside the strut, with another leveling kit that mounts on top of the strut assembly, like the Rough Country 2.5" leveling kit for our truck. He got a total of about 4" of lift. And he installed 2" axle blocks in the rear. He has 2WD though.
I think the streetridepro.com is actually AIM Industries, under a new name, because they were so bad, that they had to change there name to stay in business.
That said, I wish SOMEONE would buy one of there kits. But i hear returns cannot be done, and that instructions or customer service are non-existant. BUT if you know what your doing, and the part is quality, it will work right?
I know all about chassis tech, they are not reliable and have caused a lot of problems with guys on other forums. Like I said this is my 3rd dakota. I am not new to these trucks. I think I am looking to go 2-2.5 inches in the front. I need to do some cv driveshaft measuring to make sure there is clearance but I think this is the most we can go on our trucks.
