Rear Sway Bar
The TRX-4 does not come with the factory sway bar. It is a “delete” item on the window sticker. 05~07 suspensions where one inch higher from the factory with the TRX-4 package. I want to add the sway bar but the dealers parts department price for the total parts kit is close to $400 and that’s insane. It might not even fit because of the on inch lift. Anyone know of a 3rd. party who might have one? I’ve been all over the web and no one has made one for a GEN III. I can get them first & second gen.
just a thought, you may need to get one for a chevy or ford and have it modified to fit. basically a sway bar ia a sway bar. they just make them for different rearend housings, and leaf springs. might have to do some measuring and check to see who is closet
Later on I did make up lift blocks and raised my anti-roll bar 1". This was done for 2 reasons.
1. So my Mag-Hytec cover would clear
2. So the geometry would return back to stock (stock TRX that is- 1" higher than I was stock)
Find a scrap yard and get a used one. Should be maybe $150 total
I have lifted 4 vehicles so far a few jeeps and a few dakotas, the sway bars for one inch will not be a problem. I used the same sway bar links on a 3 inch lift for one vehicle and they were stock so you will have lots of room for the stock sway bar and links.
