Wheel Adapter
Depends what kind of damage you're referring to. The worst thing usually about wheel spacers is that some people don't realize that the amount of wheel stud threads is shortened by the thickness of the spacers when they mount them. Typically they are only 1/4 to 1/2" thick. But, if it's too little threads, it can end up stripping the them out and then you lose your lug nuts. No one needs to be told what the result is when that happens. :/
Sticking your rims and tires out another 1/4" with spacers certainly shouldn't increase the load that much to damage anything. Adapters, on the other hand, are typically a lot thicker than spacers, which definitely puts more load on the ball joints and suspension components, which could lead to premature failure. Especially with the less-than stellar engineering on the front end of our Daks.
you're on the right track... I have 2" spacers on the front of my 07. I replaced the studs with some heavy duty 5/8 ones, and its been fine. However these will only be on there for another two months or so, or until i finsh my new boxed lower arms
