The Best (Rancho's!!!)
Old Apr 28, 2009 | 08:28 PM
lghtngblt02's Avatar
lghtngblt02
The RAM Administrator
Originally Posted by ericemery
honestly, I dont feel the major bounce that everyone bitches about. I have it, I am sure. but to me, its not as bad as you all make it out to be, to me...
x2... haven't run across the bad bounce either... it goes down up down and then its done... nothing more
Old Apr 28, 2009 | 10:55 PM
LB's Avatar
LB
x3, I get a shudder that is annoying, but never had the bad bounce, even with my original shocks that were shot at 18K. I actually like the way mine rides, more carlike than truck.
But I am curious if the Rancho's would eliminate the shutter/stutter that happens after a bump.
LB
Old Apr 29, 2009 | 07:37 AM
Paul_Aris's Avatar
Paul_Aris
Seem the sight that is linked here for the ranchos has these things backordered as do most other sites. Why is that? How long did you wait. Are the hard to put on? Also, are other brands a big improvement as well like Monroe.
My stockers ride pretty nice on the road when you hit small bumps or when you first hit a bigger bump but there seems to be minimal rebound dampening. Seems like it like driving a boat after hitting the bump. Is that what you guys experience?
Old Apr 29, 2009 | 12:13 PM
sdsdsd's Avatar
sdsdsd
Do you need to replace the top of the stru too? I think it's called a strut plate.
Old Apr 29, 2009 | 12:30 PM
mprohr's Avatar
mprohr
Inspect your plate for rust, damage, bushing wear or play. If it looks fine, it probably is. However, they are cheap enough if you just want to do that too. Complete lack of rebound control is the main problem with the stockers. There must have been a better run of shocks that the non-complainers got, because if you had mine, there was no doubt they were a huge problem. And yes, the Rancho's do help a lot with the shutter, but do not completely eliminate it...it is still a truck with leafs.
