"CAI" questions
OK, for those of you that have "CAI's" does the sheetmetal that comes with them have a bottom and form a complete closed box when the hood is closed? If so, aren't you still limited to only the air that can come in thorough the small hole in the fenderwell?
If it is not a sealed box, is it really a COLD air intake? seems to me the stock airbox would be more cold air than it.
Just looking for input, I added an airaid intake tube, now thinking of opening the hole in the fenderwell to 3 or 4" ducting to the factory airbox, thinking it would produce the same results without the noise.
LB
LB
My intent is to cut out the opening and eventually run it through the fender to the bottom of the truck. I'll probably use pvc and some kind of quick release or something for when I want to go mudding. But aftermarket CAIs are overall a lot less restrictive.
LB
LB
