Add-a-leaf for rear
Old May 23, 2009 | 01:34 PM
MonkeyWrench4000's Avatar
MonkeyWrench4000
Default Add-a-leaf for rear
Does anyone know what length, width and general size the rear of the truck needs to install an extra leaf? I want to do away with the blocks, and move to strengthening the leaf packs.
Old May 23, 2009 | 11:24 PM
donkeypunch's Avatar
donkeypunch
King Jackass
I will be experimenting with this a little bit. I have a buddy that will let me have his old add-a-leafs. We will see how it fits.
Old May 24, 2009 | 02:05 AM
baracis's Avatar
baracis
I assume that would add some height as well right?
Old May 24, 2009 | 09:04 PM
donkeypunch
King Jackass
Yes. You will be adding height according to the thickness of the spring, plus the addition height from the stiffer combination. Typically, you should see about an inch or more.
Old May 26, 2009 | 12:56 PM
studlyblueiz's Avatar
studlyblueiz
Instead of an add a leaf I thought about using the tow helpers to give a mild lift in the rear. And obviously help when I haul heavy loads.
Such as the one found on this site: http://www.suspensionconnection.com/...n/1515D05.html
Go to the instruction manual and you can see how much easier to install it will be vs having to loosen your current leaf pack from the axle tube. And there is adjustability on the tension of the springs.
By the way donkeypunch, if you do recycle an add a leaf kit, it has always been recommended to use new u-bolts and nuts.
Old May 26, 2009 | 05:10 PM
turbot_bird's Avatar
turbot_bird
I have something similar on my truck. I think it was 1500lb helpers or something like that from autozoo.
Old May 31, 2009 | 09:50 PM
Sankota's Avatar
Sankota
These are a couple of items I've been looking at. Maybe it will help.
http://www.offroaddesign.com/catalog/Zero%20Rates.htm
http://www.generalspringkc.com/index...arent=117&pg=1
Old Jun 25, 2009 | 11:59 PM
viperkota's Avatar
viperkota
arent you worried abot the leaf paks getting too stiff?
i just did the helper springs on the wifes dak for hauling a trailer...got them from o'rielly's for 30 bucks
Old Jun 26, 2009 | 11:04 AM
biker_ahoy's Avatar
biker_ahoy
I think the trucks going to get the shutters easier with the add a leaf, it's ok if u drive pavment but any off roading if going to make the truck feel the washboard gitters even more
I would recommend getting firestone air ride for the rear, I belivie there already a thread with the right set you need for our trucks. mind you if does cost a bit more around $500-$600 i think
Link to the thead of guys that have them.
https://dodgeforum.com/forum/3rd-gen...b-cab-4x4.html
Old Jun 26, 2009 | 09:55 PM
LB's Avatar
LB
I am interested, do you have a link to these or any info on the maker? I don't have orielly's in Utah and I could not find them on there website (for anywhere near that price).
Thanks,
LB
