ok you two butt buddies help the guy out, for $6.00 a napa 530080 180 degree stat is a good place to start. cooler engine is a happy engine, for $15.00 at walmart get the autolite 3923 copper plugs for all 8 of them, these are one step cooler plugs and will get rid of the shake every now and then you feel, take a look at tire pressure, the door jam says 35 psi, but the max for the tire is 44psi, i run them at 40 psi. you will notice definitly better rolling resistance. so for under $25.00 its a good place to start
