Walmart ATF+4
I considered doing it myself but I've heard to fully flush the whole system you need a special setup. Also the front diff on our trucks seems to be an enormous pain to drop the pan with the crossmember in the way. I did my rear differential myself awhile back, that was pretty easy.
If they drop the pan to replace the filters like they should be that crap will be coming out. There shouldn't be enough trash in there to matter unless you already have some serious issues with your trans anyway.
The front dif is not that bad, just takes time with limited clearance with the wrench. AND after cleaning everything up BEFORE putting gasket sealant on practice putting the cover back in place without touching the gasket surface, do this until you have it memorized, trust me!!!
I think the manual says every 30K for trans. Jaded, I have heard the same, but in all cases these were high mimeage trans with no service ever. I think if you are under 60-70K you will be fine. If you are worried just do pan and filters first.
I have also read that dependin on where the pressure flush is applied it can push residue back thorough the trans.This is why I an #1 doing it myself, and this method is just replacing the fluid, not "flushing".
LB
LB
Me too man. I only run Mobil One synthetic in my truck. I payed for it while on the road and stopped at a Wal-Mart. I watched them try to put the cheap synthetic in and I about had a cow. Good for you man, I'm a big DIYer also.
