seatbelt dinger even when belt is on
Old Jul 29, 2009 | 09:20 AM
Blu3P0ny's Avatar
Blu3P0ny
Default seatbelt dinger even when belt is on
My seatbelt "dinger" is on and the light on the dash even though my seatbelt is on. I don't really know how to get at it or what could be wrong. It seems that sometimes if i get some slack on the belt and sit on the latch it will go away, but only sometimes. It's really getting annoying.
3 dings 12 times, only after you get above 20 mph the first time
just fyi......
I can't even make phone calls cuz everyone hears it in the background, lol
Old Jul 29, 2009 | 10:37 AM
importkiller76's Avatar
importkiller76
I would just disable the chime and be done with it. There was nothing wrong with mine but I disabled it anyway because I don't always wear my belt even though I should and I was getting tired of hearing the dinger also. Can't remember how exactly but I know one of the guys here pointed me in the right direction...
Old Jul 29, 2009 | 11:08 AM
pack154's Avatar
pack154
My seatbelt was doing the same thing. A wire came loose in the latch. Pry the latch open and make sure the wires are connected.
Old Jul 29, 2009 | 05:59 PM
Jaded's Avatar
Jaded
so, how hard would it be just to jump those wires in the latch? I was thinking of disabling the chimer, but thought that it may be used for other alerts.
Old Jul 29, 2009 | 06:07 PM
dodgetrucker75's Avatar
dodgetrucker75
You can disable just the seatbelt chime only, the instructions were in my oner's manual,
but i cant remember the exact procdure. the light stays on though, but if you jumped the wires at the latch, it should keep the light and the chime both off. good luck.
Old Jul 31, 2009 | 08:14 PM
Blu3P0ny's Avatar
Blu3P0ny
So just pry apart the latch... the plastic piece? and make sure the wires are all connected (or rig it up). I"ll see what I can do tomorrow...
Old Aug 1, 2009 | 01:36 PM
Blu3P0ny's Avatar
Blu3P0ny
I pried apart the reciever piece of the seatbelt. I tried connecting the wires... no luck... I tried keeping the wires seperate... no luck...
any other ideas?
Old Aug 27, 2009 | 09:42 PM
Blu3P0ny's Avatar
Blu3P0ny
Looks like i'll have to take the seat out to get at the wiring...
Stupid dinger
Old Aug 28, 2009 | 12:37 AM
popsnbeer's Avatar
popsnbeer
in for an answer on how to disable the dinger for having my seatbelt off!
Old Aug 28, 2009 | 07:56 AM
lghtngblt02's Avatar
lghtngblt02
The RAM Administrator
Here ya gues go if you wanna disable the belt chime:
NOTE: The following steps must occur within the first
60 seconds of the ignition switch being turned to the ON
or START position. DaimlerChrysler does not recommend
deactivating the Enhanced Warning System
(BeltAlert).
1. Turn the ignition switch to the OFF position and
buckle the driver’s seat belt.
2. Turn the ignition switch to the ON position and wait
for the Seat Belt Warning Light to turn off.
3. Within 60 seconds of starting the vehicle, unbuckle
and then re-buckle the driver’s seat belt at least three
times within 10 seconds, ending with the seat belt
buckled.
4. Turn off the engine. A single chime will sound to
signify that you have successfully completed the programming.
The Enhanced Warning System (BeltAlert) can be reactivated
by repeating this procedure.
NOTE: Although the Enhanced Warning System
(BeltAlert) has been deactivated, the Seat Belt Warning
Light will continue to illuminate while the driver’s seat
belt remains unbuckled.
