Stumble
Old Sep 5, 2009 | 03:37 PM
Frenchy's Avatar
Frenchy
Graythang, isn't that what you said about Graythang I?
Old Sep 5, 2009 | 06:05 PM
graythang's Avatar
graythang
That's what happens when you give secound chances. It is hard enough to buy American made and when you do you get burned. Doing the right thing is not always the right thing. My bad.
Old Sep 5, 2009 | 07:11 PM
Mahadigus's Avatar
Mahadigus
If I remember correctly,don't you have an HO motor gray? If so you need to run 3922's they are a heat range colder than the 23's that should help out alot
Old Sep 6, 2009 | 01:09 AM
graythang's Avatar
graythang
OK I havn't install them yet (rain all day) so I'll take them back & get the 3922s. What the hell anything worth a try at this point. Thanks
Old Sep 6, 2009 | 05:43 AM
Cuban11182's Avatar
Cuban11182
What about fuel filter? How many miles do you have on your truck? Might be worth looking into as well. Maybe clean the TB.
Old Sep 6, 2009 | 10:20 AM
superdak05's Avatar
superdak05
another thing to try, get intouch with the dealer and see if there are any updates that the truck needs. when superchips destroyed my pcm, dodge had to reflash my pcm and they said there were new updates that they installed. 92.00 for the reflash with new updates. you may need this done
Old Sep 6, 2009 | 01:28 PM
graythang's Avatar
graythang
There are no fule filters are there? if so don't tell me there in the tank. I did clean the TB and all sensors. I will ask the dealers about ECM updates. They should do updates free. Its not like we can down load these and just plug in the laptop and install them.
Old Sep 6, 2009 | 01:49 PM
Altair's Avatar
Altair
Dak attack!
Well I won't tell you that but the service manual might:
Let me know if you want me to post up the tank removal.
Old Sep 6, 2009 | 04:56 PM
graythang's Avatar
graythang
Thanks. That not going to happen. They just couldn't done this the old way with a seporate filter under the hood? If it ends up being the tank filter then I'll live with it and sell her in next year as is. I'm not dropping any extra money in thing anyway from here on out.
Old Sep 6, 2009 | 05:47 PM
lghtngblt02's Avatar
lghtngblt02
The RAM Administrator
I havent had any flat spots with my 07...it pulled hard even before I tuned with SC.
