Looking for some info on CAM install
Old Sep 11, 2009 | 11:30 AM
lghtngblt02's Avatar
lghtngblt02
The RAM Administrator
ok I gotcha, some reason I knew that but it was a tad unclear
Old Sep 11, 2009 | 04:16 PM
Blown287's Avatar
Blown287
Originally Posted by ericemery
asembly lube or motor oil? lol
Congrats Eric, I'm glad you won them . I used motor oil and coated them really good before the install.
Yes, the HO cams are a direct replacement so they do no require lash caps or beehive springs.
Old Sep 11, 2009 | 10:27 PM
superdak05's Avatar
superdak05
you bought used cams? not a good idea. make sure they have the correct stamping on them, also one cam should be longer than the other. if they are new, you are good to go. yake your time. i had a engine builder do my cams, 5.5 hrs, thats also dyno tuning. but i also went with the 206.
Old Sep 11, 2009 | 10:55 PM
Blown287's Avatar
Blown287
Is there a break in period for new cams?
if so, what is it?
Nope, no break in period like the single cams. Simply swap and drive.
