Installing a remote starter
Old Oct 20, 2009 | 12:02 AM
wayfast1500's Avatar
wayfast1500
Default Installing a remote starter
I just bought a 05 with a 3.7 auto, I'm about to install a galaxy 5100rs starter and I do not have a diagram. I need to know the following wire colors
Brake input
tach input
dome light
ignition
parking light
horn
starter output
constant 12 volt 25 amp (2 different)
heater/ac power
12 volt on with ignition
good ground
hood pin wire
if anyone has experience with this alarm or a alarm in this truck I could use suggestions. Thanks in advance
Old Oct 20, 2009 | 09:50 AM
popsnbeer's Avatar
popsnbeer
not sure about the colors...but have you checked the service manuals in the stickies? they might be there :-)
Old Oct 21, 2009 | 11:31 AM
wayfast1500
Best buy refused to print it, they said there was insurance issues but I did pull one up online. Looks like I only need the resistors for the door locks, and I need a relay for both the dome light and parking lights. I can get 2 standard relays right? Where did you guys mount the brain and shock sensor? I was thinking shock sensor on the fender next to the battery and brain behind the stereo if I have room, and use the stereo switched power for the switched power and the stereo ground for the ground wire.
My starter calls for one ignition input and 2 outputs, my wire list shows 3 ignition wires but does not say if they are in or out, does it matter which ones I use?
Old Oct 21, 2009 | 11:53 AM
Crazy4x4RT's Avatar
Crazy4x4RT
The stickys has the service manual that will work for 05. They will have wiring diagrams.
Old Oct 21, 2009 | 10:10 PM
wayfast1500
Ya I downloaded that too, but it didnt show me what I needed to know. I just called the company and had them email the wiring diagram.
